Help with Woods Mower for Allis C
pcheffernan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pcheffernan Quote  Post ReplyReply Direct Link To This Post Topic: Help with Woods Mower for Allis C
    Posted: 29 May 2023 at 2:15pm
Just bought a 1944 Allis C that has a Woods belly mower.
The hydraulic lift actuator is leaking and needs to be replaced or repacked
I have been looking for manuals, or part numbers but have not found anything.
Any help is greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2023 at 4:24pm
does it use the standard Allic B-C cylinder ? maybe a 3/4 inch rod... od of cylinder is like 1.25 inch... pin connections on each end... single acting, hose connects at the back end ??
Edited by steve(ill) - 29 May 2023 at 4:29pm
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2023 at 5:29pm
Woods L 59 or L 306 use the C hyd cylinder fliped to face foward. Have you tried tightening the packing nut. The only thing in that cylinder are the leather packings under the packing nut. I just took mine out by removing the nut pull the rod out and the leathers pop right out. Went to the local hardware store got 3 leathers for a pump cut them down and put it back together. Soak the leathers in oil first. Tighten the packing nut snug. Run it some and tighten again mines been good for 25 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pcheffernan Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2023 at 7:23am
ActuatorActuator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pcheffernan Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2023 at 7:25am
I just posted a couple photos of what my actuator looks like. I'm struggling trying to post photos and put text together as I'm new to this. Sorry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pcheffernan Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2023 at 7:28am
I have not tried your suggestion, however I will. I was actually looking for a part number for this actuator, or part number for the seals. Wasn't aware I could go to a local hardware store for seals. Didn't know they were made of "Leather". I obtained a Woods L59 owners manual, that shows parts breakdowns, however it does not show this actuator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2023 at 8:50am
the CYLINDER is made by Allis Chalmers.. It is not part of the WOODS system.  You need packing for an ALLIS cylinder... You can use the old leather type, or you can use newer plastic VEE packing... Note that many of the ON LINE vendors list a larger size packing (WD 45 size) for the B and C... Yours has a smaller rod... check that ... 3/4  dia... Not 1-1/4 inch..
Edited by steve(ill) - 03 Jun 2023 at 8:58am
