Help with my C |
Brian Jasper co. Ia
Topic: Help with my CPosted: 05 May 2010 at 11:08am |
It can be done from the front. If you remove the ft cover, you will need a special alignment tool as there are no dowel pins to line the cover. When I overhauled my CA engine, I had it standing on it's flywheel and let the new seal center the cover while I carefully tightened it down. |
MilesGray (CO/KS)
Posted: 05 May 2010 at 10:15am |
My C has started leaking oil (from a place I have not seen it before, lol!).
It looks like it is coming from the rear of the camshaft pully on the front of the engine.
I have had the Alternator come off due to a bad welding job by the previous owner and had to fix it.
My question is, do I have to take the whole engine apart to replace the seal or can it be accomplished from the front? I have never had any problems with the engine before and would rather not tear it down if I don't have to.
TIA
Miles
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy! |
