Help identify mounted coil tine harrow on FC
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: Help identify mounted coil tine harrow on FC
    Posted: 27 Sep 2023 at 8:38pm
It's on my newly acquired 1400 field cultivator (Chiselvator) and need a few parts for the rear harrow. I can't ID it so I was hoping for some help. Thanks
Edited by Lonn - 05 Oct 2023 at 10:08am
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2023 at 8:40pm
I need a hold down spring, brackets and a couple bars that the tines bolt to.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 9:49am
Try again. I hope someone can help. Mainly I need a spring and the plugs on each end of the spring. Thanks
Wink
I am a Russian Bot
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 10:25am
I found without the down pressure springs I like my harrow much better. Trash flowed thru my cultivator only to plug the harrow.  Then everything was a mess.
Wink But it is the off brand the local AC dealer promoted much more than the AC brand of tillage tools.
Have you tried looking at McMaster-Carr and find a spring by dimension. But that would still leave you in need of plug.
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 7:24pm
Remlinger Manufacturing. Kalida, Ohio.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2023 at 9:56am
Thanks guys I will take a look
Wink
I am a Russian Bot
