heald hauler |
Post Reply | Page <12 |
MNLonnie
Orange Level Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
The 3 wheel version must be more common, I see there are 2 of them for sale in MN. One for $900 and one with a dump box for $1200.
normlf
Bronze Level Joined: 23 Nov 2014 Location: Mazomanie Points: 11 |
The one I have is four wheeled with a cab. It has head lights and a tail light....and brake light. It has electric windshield wipers as well as a dent free dump box. It even has usable OEM doors.
It also has turn signals......I am going to rebuild the carburetor......as oddly enough, it's run good for a couple of years that I know of....and now it's giving me a bit of trouble.....my bad luck. But not a major item...more of an irritation. I have not decided on the sale price yet, but given everything involved, I suspect I'll be over $2K in asking. Norm |
MNLonnie
The 4 wheel version is a much nicer looking machine by far, I don't really care for the looks of the 3 wheel ones.
Dusty MI
Orange Level Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5053 |
One of the electrical contractors that I have worked for had a Cushman much like that.
Dusty
Herb(GA)
Orange Level Access Joined: 15 Sep 2009 Location: United States Points: 1011 |
You certainly hit the jackpot Norm; machine looks great, and a nice dump box. Son gave us an electric golf cart after I got hit with scoliosis. We have 2+ acres of gardens. We don't like getting wet when a small shower occurs. Problem is how to double roof size using some foldaway method so easily stores inside. Plan adding a readily removable, powered, hinging dump box; hope to find one at bone yard of some large golf cart dealer.
normlf
I am not sure if I'm at the right place...but if not, I apologize.....
I am working on a nice Heald Hauler with a cab and doors...and in nice shape for a machine of that vintage. It has developed a problem....it starts good, idles properly and runs decent at mid-level rpms, but seems to run out of fuel when at elevated rpms. I assumed a problem with the carb or the built in fuel pump. Ordered a carb kit and dismantled and carefully cleaned the carb and made sure all passages were open.....three way, mechanically with a piece of fine wire, compressed air and carb cleaner. All new parts gaskets, needle, idle screw, gaskets and also all internal fuel pump parts. No better!! Replaced fuel line and filter....no better. Took the carb apart again in case I missed something.....no better. Put a new hose from crankcase to pulse input barb on the pump....seemed a little better.....made sure passages was opened to crank case with probe and compressed air and then some carb cleaner....no better. Does anyone have any idea what might cause this condition.....and suggest any fix......HELP Not new to this sort of work....but I am missing something and don't know what it must be.... When engine starts to falter...if one lets up on throttle it will recover...and run decent..... I'm missing something.....ideas welcome...and hoped for. |
MNLonnie
If you think it might be the fuel pump/supply issue could you put an electric one on for the time being to see if that eliminates the problem? That way you would know for sure on that part of it.
normlf
I thought about that and borrowed an electric pump from a neighbor.....but the pump pressure from the Briggs pump is 1.5 psi....and the automotive electric pump should put out 4 to 7 psi....and might well destroy the diaphragm inside the carb mounted pump....and just spent $21 for a kit that included the new gaskets and springs and diaphragm ...... not sure if I want to take that risk..
Any idea what might cause the pulse from the crankcase to be compromised....if that pulse is weak...the pump would be weak as well....just guessing what could affect the pump performance...a shot in the dark.... |
MNLonnie
Would a bad seal in the crankcase cause a poor pulse? Would it run on a gravity feed tank, it surely can't use more fuel than what will gravity flow into it.
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10579 |
Check the fuel tank vent or vented cap. HTH tracy
farmer0_1
Orange Level Joined: 06 Dec 2009 Location: cornelius or Points: 592 |
i like the gravity feed idea , at least temp it that way to see how it runs. got a boat fuel tank?
Dusty MI
x2 Dusty
normlf
I guess it might, but I would think that a bad crankshaft seal would be showing oil.....and this one isn't doing so. I spent some time last evening scanning through a manual for that engine and found a note about crankcase vacuum.....it suggested that a bad grommet at the base of the dipstick tube or o-ring under the dipstick cap could affect crankcase vacuum....it didn't say, but that implies it could alter the pulse and thus affect running.....I'll check that out.....the seal idea makes some sense.
Anyone else have the same type of problem....??? Or can you suggest any ideas. Norm |
normlf
test/////
normlf
I spoke to a man who works for a dealer that sells and services all manner of small engine products as well as parts. He's worked there for 30 years. He listened to the symptoms I described and advised, if it starts and runs even into mid-range RPMs....that the pump isn't the issue....they either work or they don't And the carb is not the issue if it is clean...which it is. He suggested that two areas could be involved. One was the fuel as modern fuels with ethanol are different from the fuels of the 70s when that engine was designed and built....and he suggested refueling with premium level fuel.....which I will try. The other is that something could be affecting the strength of the pulses that operate the fuel pump. I've replaced the hose from the crankcase to the pump.....but some sort of leak with the dipstick tube....either the o-ring on the cap or the grommet in the crankcase could be leaking...and degrading the strength of those pulses .... Has anyone had any experience with either of these issues......what did you discover and / or fix?
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9325 |
I would still try a remote gas tank hung above the carb and not running through the fuel pump. I have a large fuel filter that I cut one end off of and have a piece of rubber fuel line on the other. I have started and ran a lot of motors with it through the years. I had a kohler on a welder that I like to never got to run right. I did this to it and it ran well. I wound up buying an electric fuel pump from a small engine place to fix the problem.
Daveadams
Bronze Level Joined: 24 Jun 2017 Location: Iowa Points: 2 |
Thought I would add this it runs good and is for sale make me an offer thanks for looking
Daveadams
Walter C
Bronze Level Joined: 29 Sep 2019 Location: RI Points: 1 |
I would like to know, if you still have this equipment? If so, would it be possible to get a picture of the nameplate decal on the side of the dump body. I just purchased one yesterday and I am looking for information.
exSW
Orange Level Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2279 |
A friend of mine has a 3-wheel model. His grandfather bought it new and it's still in the family. they use it to pick up rocks in the field. I used it for that 12 years ago and the dump box is neat.
allis g
Orange Level Joined: 10 Jan 2012 Location: Templeton Points: 402 |
Friend has one similar it’s called a turf-truk. Made in Turlock CA. bought brand new in Paso Robles CA at El Camino Equipment. By his grandpa in the early 70’s. Has a flat bed about 4’x4’ Harley Davidson disc brake on the drive shaft. Honda 10 horse engine from the factory, golf cart frame, and what looks like a ATC front end. Just this year finished a restoration on it. It was used to haul almonds back in the day.
draacul
Bronze Level Joined: 09 Nov 2019 Location: Texas Points: 1 |
LOng shot as it it is 4 years ago but i think i have the same heald hauler with the same stuck in reverse issue. Did you ever figure out more info on yours? Please contact me if you have some help. Not much about mine out on the interwebs. Thanks
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
My older brother had the Herald Super Bronco mini bike. I think it had the 10 hp engine on it. It would really go if you reached back and grabbed the governor. I think I have a picture somewhere.
1957 WD45 dad's first AC
Kiwi
Silver Level Joined: 23 Jan 2018 Location: New zealand Points: 379 |
Hi all the herald hauler is a pretty cool machine I had pleasure of spotting a duzgo which is a New Zealand build machine which is similar www.spirit magazine.co.nz>it duzgo it is a pretty good story
LeonR2013
Orange Level Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Two things you could check is the clearances on the valves, or if the guides are worn bad you could lose vacuum both ways and so have a low pulse. Could you put the fixit on here when you're done. Thanks. Leon
