Head Gasket Instalation |
BLee Mn ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Montevideo Mn Points: 680 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Feb 2012 at 12:53pm |
ready to put head back on my WF, Do you guys install head Gasket Dry or use a gasket sealer?
Cowboy UP
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Unless the gasket specifically calls for a sealer, they go on dry.
Still in use:
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
I always spray mine with copper or aluminum spary paint, let dry for 5-10 minutes. Don't know if necessary, however, it used to be that the gaskets came off easier when treated this way.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3866 |
Blee what brand gasket do you have? victor or felpro are both ok, they have metal rings around holes for water- oil- and compression, some junk gaskets don't have them. If its a good gasket dry is ok although I knew a old AC mechanic that sprayed his with aluminum paint as Greg sugested. head should be re-tourqued after warmup!
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
used alum. paint for 50 y rs. will always come apart have painted it twice an used it over
in the 1960,s and up
Cowboy UP
Eric B ![]() Orange Level ![]() ![]() Joined: 09 Feb 2012 Location: British Columbi Points: 968 |
Another sure proof product to use is a pipe joint compound called "Blue Magic". I've used it on reasonably good old gaskets that were hard to buy any more (as well as on some new ones). On gas or diesel engines we've never had a failure or leak in 38 years. You only need a very thin film of this compound and don't get it on your clothes 'cause you'll never ever wash it out with anything.
Dave in il ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
I use coppercoat spray
AGCO My Allis Gleaner Company
Bill Long ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Please don't laugh, but when we did them we used shellac. Remember this was in the 40's and 50's.
Worked well for us then. I'm certain there is better stuff available now. Good Luck! Bill Long |
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
At one time there was some called Gasket Shellac.
Today many head gaskets say right on them DO NOT COAT. Dusty |
Bob D. (La) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Louisiana Points: 25529 |
Something I learned many years back,probably 50's or 60's. Coat both side of head gasket with a thin coat of grease. Never had one fail so I still do it to this day.
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2262 |
These engines (unless worked) don't have particularly high compression so installing them with nothing is probably fine. Some gaskets may even instruct you to do it that way.
Having said that, I use aluminum paint; spray one coat and let dry; spray a light second coat and install wet. Necessary? Probably not!
I originally got the idea from an old time Ford mechanic who told me this was the method Ford recommended when they started to jack up the compression on the 312 Y-Blocks.
Reindeer ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Calgary, AB Points: 650 |
The aluminum paint sounds like a nice idea. My father was a mechanic during the construction of the Alaska (Al-Can) highway during the war, and he used the grease method, so that is what I have done on a couple of heads. So far, no problem, touch wood!
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Has the gasket got metal on both sides? If so we used to spray them with permatex hitack. Both sides twice and let dry to a tackyness. This was how the old mechanics did it at the AC shop I worked at. Also on WD45 on down to the WC WF they also put a length of packing string in between the metal jacket on the side with the three 3/8" studs to prevent water seepage. This was done to the full length of the gasket on that one side. The D17 engines solved the problem with 7/16" studs torqued down tighter.
More modern no retorque gaskets I've left dry.
Wink I am a Russian Bot |
yes gasket has metal on both sides, thanks for all the ideas guys!!
Cowboy UP
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41980 |
Copper coat is what I use on most gaskets, use to use the Aluminum spray paint but the copper coat seems to work better (either spray or the dober to thin coat it) .
M Diesel ![]() Silver Level ![]() Joined: 26 Feb 2010 Location: Las Vegas Points: 128 |
Same here. I generally use a film of anti-seize. It is important to let the head settle without binding and a little lube makes all that happen. (Sequencing alone is not thorough.) That is mostly what actually happens with the various paints. |
