HD^G Loader
jnielson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnielson Quote  Post ReplyReply Direct Link To This Post Topic: HD^G Loader
    Posted: 14 Jun 2011 at 2:39pm
I just bought a HD6G  and am looking for Truck rollers have 2 that are worn into
Also I am working on getting this Machine Running  Replaced all the fuel filters Blew the Lines out and have the fuel system reprimed to the Pump but No fuel out of the pump that I can tell  My brother is going to be here tonight I will get his help  but does anyone else have any idea's the Machince will start and run on either
This Machince sat for at least 5+ years I think the injector Pump is a Bosch
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnielson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 8:33am
Update  Found a stuck fuel shut off vale in Injector  free and know the machince is running  Very cold Blooded I do a a fuel leak on the Manafold Injector Tube and am know looking for a source to get the rubber O Ring  This is causing fuel leak off and once that is fixed I hope it will start easier
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 9:54am
HD5 and HD6 rollers, sprockets, idelers and such undercarrage are all the same size as is the rear housig.
 Track is the same pitch , just the length in links differs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnielson Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 11:06pm
Thanks Coke  my HD6 is down again  looks like the hot summer took the seal out in the injection pump pulled the dip stick and i have desial fuel in the oil
now looking for a overhaul manuel before i pull the pump so i can have everything right before I pull the pump
This page was generated in 0.615 seconds.
