HD6 DOZER VALUE??
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Topic: HD6 DOZER VALUE??
    Posted: 07 Nov 2013 at 7:34pm
I have a chance to buy a HD6 dozer for scrap price, it ran about 12 to 15 yrs ago and it ran when it was parked in the shed,it has a power shift trans, and i think it was blt in the late 60s to around 70,,,,so what do you all think?????????? ps. it also has a brush guard/ cab on it, and i think its either a 8 or 10ft blade. THANKS TOM
Edited by ctbowles58 - 07 Nov 2013 at 7:38pm
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2013 at 9:49pm
Track is the one part that costs IF it is shot - it's hard to find now .
As a parts machine one could do better than scrap price if one took the time to dismantle it - or as a supply while you look for another machine to use the parts on.
 I wanted a HD6 for a while but made do with the HD5G and HD5B  I had - then mater machines seems to have made the track loader less the workhorse and my backhoe and then excavator became main machines of use.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2013 at 12:31am
If it's more to play with then work hard it should be a nice machine for the price, if it runs and moves.  Having a trailer big enough to haul it is a plus.  Can get expensive if you have to pay to move it each time.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2013 at 4:26am
If it's more to play with then work hard it should be a nice machine for the price, if it runs and moves.  Having a trailer big enough to haul it is a plus.  Can get expensive if you have to pay to move it each time.its mostly to play with, i do have some brush, and a few fence rows i would like to clean up, but no real hard work.
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2013 at 7:43pm
Unless it is junk, I'd likely take a chance on it. I owned one and it was a great little dozer. Attach a picture, please.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2013 at 10:17pm
Please post a picture. I have (2) but they are a 1961 model and 1956 model.  I would like to find a newer model with power steering and brakes. This one should have those features.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2013 at 9:08pm
if i get it bought i will, its takeing a long time it is in an estate.
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2013 at 9:49am
I had my HD6G on eBay with a reserve of $4500 bidding went up to $3800 so I still have it. I have another HD6G that sat for 2 years while I was rebuilding the motor. Now that the motor is running the steering clutches are frozen. If you are looking at a newer machine that has the newer steering clutches this might not be an issue. There are (3) shovel designs on HD6G's. The 3rd design starting with S/N 11094 have a double link on the dump cylinder is desirable. On the older shovels the hydraulic cylinder is in single shear. On a hard dig you can bend the cylinder rod. Been there done that.
