HD5G in Idaho (part 2)
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: HD5G in Idaho (part 2)
    Posted: 21 Mar 2021 at 8:41am
With the weather finally permitting, we got the track split and removed the right front idler; the gauge on the 50 ton press indicated 40 tons of force before the shaft moved. As you can see in the photo, it was not done soon enough.
We need two (2) of these:
RETAINER, bearing P/N 073646
Or perhaps drawings with dimensions so as to be able to build up and re-machine these.
Thanks for the help.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2021 at 5:15pm
I check tomorrow if am still have some retainers bearing
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2021 at 10:32am
Hey Les, That piece can be repaired or a new one fabricated as you stated if you can figure out dimensions, just a word to the wise, if you try to arc weld to most of those cast pieces they can turn harder than the hubs of hades. Brass or torch rod would be the way to go for me. Should Gemdozer have one, it might be a good idea to duplicate it to CAD for the next guy.  Best of luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2021 at 4:32pm
I 0nly have a retainer bearing 073646 but not in very good condition the stell ring and boot seal are losed in
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2021 at 5:35pm
I made a mistake the seal rings and boot assambly are instaled in the bracket  or in the retainer seal rings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2021 at 6:12pm
If it is usable I am definitely interested.
We are also in need of seals and bearings.
Does anyone perchance have a complete idler for sale?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2021 at 6:02pm
I have the retainer bearing with the cup and used bearing and have a other one cup and bearing and have 2 rings sealand the parts are usable and no more boots spring assambly
                                  gemdozer@hotmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2021 at 9:36am
Thanks for the reply, I sent you an email.
This page was generated in 0.211 seconds.
