HD5G final drive leak |
51HD5G
Topic: HD5G final drive leakPosted: 26 Jun 2024 at 11:21pm |
Changed final drive oils with 50 weight and on clutch side the oil leaked out rather severely. Contemplating packing grease in, but you guys way smarter than me. Any suggestions? Many thanks!
gemdozer
Posted: 27 Jun 2024 at 6:55am |
No greace in cluch and final drive
Les Kerf
Posted: 27 Jun 2024 at 12:29pm |
Hmmm... are you referring to the left side of the machine?
51HD5G
Posted: 27 Jun 2024 at 12:51pm |
Left side from sitting in seat. Seems to the inside seal or whatever as it's mainly dripping on the inside portion of track.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42261 |
Posted: 27 Jun 2024 at 12:55pm |
Upper shafts into clutch housings are LIP Seals . Oil level on outboard side should never be high enough to pour out , on inner side the level is set by level in transmission level.
Outboard seal of final drive is axle seal which is a mechanical seal on sprocket . |
51HD5G
Posted: 27 Jun 2024 at 1:12pm |
What about filling final drive to level of cap on rear of tractor? I replaced transmission oil to level of plug on side of transmission. Does transmission oil comingle with final drive oit?
Coke-in-MN
Posted: 27 Jun 2024 at 1:21pm |
NO - final is set by the level in the plugs in the drawbar , bull gear movement distributes the oil to gears and bearings within that case . Transmission oil is separate and lubes ring and pinion and gears in transmission case only.
Lower case uses a different oil also . |
