HD5A Allis Chalmers
Message Reverse Sort Order
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Topic: HD5A Allis Chalmers
    Posted: 23 Sep 2011 at 6:43am
Has the alert little terrier sensed one of the hazards Tad mentioned?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 8:21pm
I didn't notice the bare feet till they were mentioned, but I did notice the dog. Seems like there is something of interest to the right of the picture.
q4016lanz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 7:04pm
WOODBUTCH No goatheads around hear but there were some at the rally i went to last weekend 300km away at the moment the snakes are out every were around here you see them rum ocer on the roads every where. My son slashed the neighbour acre block and slased up 4 of them 1 taipan 2 red belly blacks and a python thats why i keep my grass short
15 allis chalmers tractors
9 lanz bulldog tractors
2 water cooled deutz
9 john deeres tractors
14 Aus made orange chamberlains
I spent most of my money on old tractors I wasted the rest
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 4:10pm
Goatheads????? HAHAHAHA! there are those who say "what is a goathead?" I think all that rode bicycles as a kid in rural USA should and probably know what a goathead is,(they prey on old worn tires) they are also called puncture vine here in CA, One learns very quickly never to put one's hand on a tractor or baler tire and one must carry a carpet or cardboard to work under anything in an Alfalfa field, those little $#*$#$^%^ hurt like hell, especially in fingers and knees and bare feet. Since it seems as though everything that bites, stings or pokes Down-under is toxic to the extreme, they must have an equivalent to the goathead that will kill you in 30 minutes or less. What say you? (insert smiley face here). Tad
woodbutch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodbutch Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 8:35am
I'm guessing, no goatheads in qld!
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 4:44pm
Yes ACER there are Queensland safety boots most farmers in the sub tropics don't were boots thats my son bare feet i'am a old bloke i were safty boots these days. cheers john
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 8:37am
Mainly draw bar work , Ag tractors, pulling loads, with winch added - skidding logs,
see there are trunions welded onto truck frame so at one time liiks like it had a dozer blade on machine . at 50 HP and no slip should be able to pull about the same as 75 to 90 HP wheel tractor in plowing with little or no compaction.
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 8:17am
are those bare feet i see
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 7:57am
HI Coke what were they used for and how many HD5A built cheers john
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 7:51am
5G used a longer truck frame, had a solid cross frame instead of equalizer spring, area for operator was smaller , shift lever different, running board area cut down for loader frame. smaller track grouser and smooth 3 bar type look.
 Lot of work to change over to loader , also counterweights are needed to balance machine.
Edited by Coke-in-MN - 21 Sep 2011 at 7:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 7:25am
Were the HD5A built for ag work on the farm our hd5a has 2 revers gears i would like to put a loader on it if possible
