HD3 engine swap?
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Topic: HD3 engine swap?
    Posted: Yesterday at 4:37am
Got a salvage yard crawler with a bad engine. No injection system now and engine turns stiff. Anyone tried to put another engine into a HD3?
What would be a good transplant engine to set in it if able to do so?
 Or does someone have an old Allis-Chalmers diesel 175 cube engine laying around that was taken out of HD3/ D15D that would be usable for donor parts?
 Here is a pic of crawler, blowing critter nests out of valve train area cuzz valve cover was sitting on the two studs.
 On market place, seen a Simpson SJ436E engine says 46 kw, and a Perkins 404...Also a 4 cylinder Mercedes OM616 2.4L Would that make the crawler run like a Cadillac?
  I might have to go hunt down a D15 160 cube engine and put in, probably be the easiest avenue to go.
   Sure would like to keep it diesel.
        Thanks, JC
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:12am
Got a couple here pm me
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 52 minutes ago at 6:10pm
I don't know how far you would go to hunt for an engine? A guy in Canada (in BC) swapped out a 175 diesel in his forklift and put in a Detroit 2-53. I know he was trying to get rid of the 175 but don't know the outcome. This is the guy:
He has a thread on the forum here, but the 'search function' is not doing anything for me.
Eric
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 19 minutes ago at 10:43pm
H4 AC used a 2200 AC engine that was also used in cotton pickers and few other units , it was a gas or diesel engine basic and turbo or natural aspirated in different applications
The Allis-Chalmers 2200 (often referenced as D2200) is a 4-cylinder turbocharged diesel engine utilized in various Allis-Chalmers agricultural and industrial applications, including tractors like the 6060, 6070, and 6080. These engines are known for their reliability but may require overhaul kits for maintenance
https://www.google.com/search?q=Allis+Chalmers+2200+engine&rlz=1C1HKFL_enUS1206US1206&oq=Allis+Chalmers+2200+engine+&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCjE0MzQ1ajBqMTWoAgiwAgE&sourceid=chrome&ie=UTF-8
Edited by Coke-in-MN - 8 hours 14 minutes ago at 10:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 46 minutes ago at 4:16am
That's a nice looking D2200 engine there in your link Coke, just wish it was closer instead of next to the Washington state border.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 17 minutes ago at 4:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 minutes ago at 6:32am
As far as I have been able to determine, the 2200 series engine (G-2200 gas/D-2200 diesel) was never turbo-charged. I had it in my head that there might have been a D-2400 that was turbocharged, but can't seem to come up with anything by googling.  I thought I read that a D-2400 existed from a head gasket installation instructions sheet many years ago. The newer 1978 433-T and 433-TI engines were the first to be turbocharged and turbo/intercooled. They also were equipped with a Lanchester style engine balancer in the bottom of the engine so they could operate at 2500 RPM. These changes allowed the flywheel HP to reach the 100 flywheel HP mark where the D-2200 only ever got to 50-52 flywheel HP @ about 2000 RPM.
This page was generated in 0.545 seconds.
