HD16DC steering problem.
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2017 at 2:29pm
Originally posted by Morten.have Morten.have wrote:
Sump filter and new Oil. And a lot of air purged between the pressure filters and the valve block.
When I got the pressure I started fine tune the pressure so left and right are acting the same, bout 500psi.
It’s a HD16DC -5319 it’s a lovely tractor with a good functional diesel torque converter.
But I can’t find out the age of it.
Mine is s diesel torque converter as well. Runs wonderful.. Picked it up in September and have been doing service and getting everything repaired. New batteries, all new battery cables, All filters and fluids. Change oil in final drives repaired frozen and leaking slack adjusters. No major engine or drive train work. Re wired gauges and added headlights.
Loving it all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2017 at 2:31pm
How do you purge air Morten?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2017 at 2:53pm
According to the book of serial numbers yours falls into tractors produced in 1961.
1961 serial numbers go from #5098 to # 5447. Hope that helps ya out.
This page was generated in 0.097 seconds.
