HD16 - info please |
Page <12 |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3670 |
Posted: 08 Jun 2015 at 11:30am |
Thanks everyone for helpful replies. The pitted rams cleaned up ok - no torn seals yet. I got the blade lift cylinder's hoses replaced & one valve fitting. It lifted the blade nicely after all those fixes. It has the optional blade tilt cylinder on the left side. It works good too.
My brother showed up to load & transport it home with his semi. We had to add 5 gal hyd oil to torque convertor to get it to crawl right. Turning it was a challenge as it's left/right hand clutches would only operate if I first pushed accompanying foot brake. I got it loaded onto his detach trailer, but felt like I needed two more hands to operate everything. Its home now. My brother told my wife, "He'll never be the same from now on. He's got a dozer now and that changes everything." He's right. This dozer needs tlc, but its just so dang fun to operate. I enjoy working on it also. When it's running, the sound of its engine is captivating. My daughter & her friend sat on it and I started it up for them. They had the same expression about how its sounds.. I hope I can get it operational enough to do some real dirt or tree pushing. Im working on getting some photos attached, but my phone's pics are being a PITA.
AC7060IL
Posted: 08 Jun 2015 at 11:49am |
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Posted: 08 Jun 2015 at 5:18pm |
Mactractor
Re crankshafts There is a little nest of Allis dozers around here - HD16 and earlier HD21's and I doubt that any have 25000 type engines. But crank cracking is a common problem mentioned. One owner tried about 4 cranks (including one with a tested tag) before he got a useable one for a HD16DP. |
Mactractor
Joined: 20 Jun 2011 Location: New Zealand Points: 652 |
Posted: 09 Jun 2015 at 4:56am |
Any idea how many hours those engines clocked up before the cranks went bad?
Ian Beale
Posted: 09 Jun 2015 at 5:20am |
Mac
Not really, but I'd guess plenty. My neighbour is away on an "expedition" but I'll quiz him when he gets back. He owns what might be a contender for the best working HD16DP in Oz. He is meticulous and has been through it from blade cutting edge to ripper boots. But the paint job is like your observation on the HD 15 thread earlier. BTW Know anything on Pacace rippers? - he hasn't found much |
AC7060IL
Posted: 09 Jun 2015 at 7:31pm |
Here is a pic of the pitted ram after I emery clothed it. |
AC7060IL
Posted: 09 Jun 2015 at 7:36pm |
This photo shows the HD16 running & its blade fully lifted after the front blade cylinders were cleaned up with emery cloth, 2 cylinder hoses replaced, front hydraulic fittings repaired, & 15 gallons of hydraulic fluid added.
Dgrader
Joined: 17 Jan 2015 Location: Newton,IL Points: 1037 |
Posted: 09 Jun 2015 at 8:27pm |
I'd say you are ready to rock and roll my friend.
Ya cain't fix stupid.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 09 Jun 2015 at 11:12pm |
That track has too much sag.That'll wear em too.
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1009 |
Posted: 10 Jun 2015 at 6:27pm |
These machines have a commanding presence when they run. You don't have to make many "pushes" before you feel productive for the rest of the day.
Mactractor
Posted: 10 Jun 2015 at 7:24pm |
Running the 11EP on a still morning, the combustion bark emitted from the short bit of straight tubing atop the turbo, has brought old time skinners from two or three miles further down my valley up to take a look |
ACcrazy
Joined: 30 May 2012 Location: Eureka, Califor Points: 97 |
Posted: 14 Jun 2015 at 4:14pm |
Any chance you could get some video of it running/working?
There isn't much at all in the way of vids online of the mighty HD-16. I think I've watched the 3 that I could find a hundred times. ![]() |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 14 Jun 2015 at 5:22pm |
This one of them? [TUBE]http://youtu.be/lujnXD8609M[/TUBE]
AC7060IL
Posted: 15 Jun 2015 at 6:27am |
Yes DiyDave, mine sounds just like that - thanks for sharing the video.
It's throttle response is impressive & always brings a smile to people within hearing distance. That low base tone of either high or low idle is there all the time :)
LANSDOWNE
Joined: 23 Jun 2015 Location: South Dakota Points: 3 |
Posted: 24 Jun 2015 at 9:00am |
I have lots of early HD16 parts 1959-1966, let me know what you need.
jerbob
Posted: 16 Aug 2017 at 12:51pm |
I know this post is back in 2015 buy couldn't resist saying, I just purchased a 1961 HD16DC.
Should be delivered this Friday. Geeked |
jerbob
Posted: 16 Aug 2017 at 12:53pm |
Hello LANSDOWNE.
Scrolling through the forum and saw you old message that you had at that time a lot of old HD16 parts. Is that still the case? Not sure what I will be needed but taking possession of a 1961 HD16DC this Friday. Curious what kind of parts you might still have. Thank you. |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4873 |
Posted: 16 Aug 2017 at 6:34pm |
Don't be looking to hard for a answer,Lansdowne has not visited since July 2015. Need to learn to check the profile by clicking on user name.
ACcrazy
Posted: 17 Aug 2017 at 7:10am |
Post up some pics of your new acquisition.
jerbob
Posted: 17 Aug 2017 at 8:02am |
I sure will. I have some already from my initial inspection but cannot get them posted. Telling me the file is too big when I am only trying to post one pic as an example. Any suggestions as to what i am doing wrong will be greatly appreciated.
meeting halter to load her up tomorrow and get her home. |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 17 Aug 2017 at 8:07am |
use paint and resize the pictures to 800x600. seems to work the best here that i have found. then upload to file manager.
jerbob
Posted: 17 Aug 2017 at 8:49am |
Will give it a whirl and thank you
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35666 |
Posted: 17 Aug 2017 at 10:14am |
I resize mine as to pixel count, usually divide by four to get small enough to load into site.
Page <12 |
