HD 9 Gear Shift
Connie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Connie Quote  Post ReplyReply Direct Link To This Post Topic: HD 9 Gear Shift
    Posted: 03 Apr 2025 at 1:03am
Hi,
I recenly purchased a HD 9 just wondering if anyone has the gear shift pattern as i am struggling to find it.
thanks in advance,
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2025 at 8:19am
You would get more replies if you post under the "construction and other equipment" section of the Forum.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2025 at 11:27am
It has been to long, but I think 1,2,3, and reverse in low and then 4,5,6 and high reverse in the high range. The short lever is the high/low. Cannot remember if high is forward or back. But only 2 choices.
Edited by Ray54 - 03 Apr 2025 at 11:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Connie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2025 at 12:17am
thanks for that, you don't happen to remember the pattern from left to right at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Connie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2025 at 12:18am
Hi, Thanks for that, i am new to the forum and im not really sure how to operate it
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2025 at 7:27am
I found a PDF online of the operators manual for the HD9 and was able to download it; it does NOT give a very clear picture of the shifting pattern though.
The manual does state that there are six speeds forward and three speeds in reverse. From the picture it shows the middle shift lever as being the High-Low selector and the one on the right side being the main selector.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2025 at 7:31am
