HD 9 Gear Shift |
Connie
Topic: HD 9 Gear ShiftPosted: 03 Apr 2025 at 1:03am |
Hi,
I recenly purchased a HD 9 just wondering if anyone has the gear shift pattern as i am struggling to find it. thanks in advance, |
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3953 |
Posted: 03 Apr 2025 at 8:19am |
You would get more replies if you post under the "construction and other equipment" section of the Forum.
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4792 |
Posted: 03 Apr 2025 at 11:27am |
It has been to long, but I think 1,2,3, and reverse in low and then 4,5,6 and high reverse in the high range. The short lever is the high/low. Cannot remember if high is forward or back. But only 2 choices.
Edited by Ray54 - 03 Apr 2025 at 11:29am |
Connie
Posted: 04 Apr 2025 at 12:17am |
thanks for that, you don't happen to remember the pattern from left to right at all.
Connie
Posted: 04 Apr 2025 at 12:18am |
Hi, Thanks for that, i am new to the forum and im not really sure how to operate it
Les Kerf
Posted: 04 Apr 2025 at 7:27am |
I found a PDF online of the operators manual for the HD9 and was able to download it; it does NOT give a very clear picture of the shifting pattern though. The manual does state that there are six speeds forward and three speeds in reverse. From the picture it shows the middle shift lever as being the High-Low selector and the one on the right side being the main selector. ![]() |
Les Kerf
Posted: 04 Apr 2025 at 7:31am |
