HD 11 EP transmission issues
dragboat1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dragboat1 Quote  Post ReplyReply Direct Link To This Post Topic: HD 11 EP transmission issues
    Posted: 29 Jun 2016 at 5:37pm
I,m looking at at hd11 EP they said it would just quit moving. Then in a little while it would start back. don't know what to look for. Was thinking about buying it just not sure weather to make the leap. Don't know if I can get trans. Parts . Any thoughts would be nice.has anyone every had this problem .thanks.
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 8:24pm
you have to be abit mechanically minded to own bulldozers; esp older ones most problems come back to maintence or lack of. if a powershift machine won,t drive or steer its usually oil related. might be lack of oil, wrong oil; blocked screens or filters. damaged lines causing it to suck air, the lists go on. All comes back to knowing how the system works and going through a process of elimination. And always do the easy things first.
Is 2 series of 11ep tractors, first series had twin disc torque converters; later ones Rockford. Were a good tractor in there day, made from about 64-70. Where replaced by The HD11 series B which came out in 70 and these were also a very popular machine.
tits tyres and tracks
they all cost you money
This page was generated in 0.211 seconds.
