Hay Wagon Stacking
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2018 at 9:06pm
    Swimming pool? We had a 200 gallon water tank with a round 35 gallon coal heater inside for keeping the water from freezing in the winter. That tank slimmed up green along the outer walls and heater creating a perfect environment for some type of black biting bug that bit us nonstop. and if you kept your head under water long enough, you gave the cows a good startle when they took a drink. And we liked it !
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2018 at 9:21pm
 Like Brian F.(IL) we had a "bale fork" that had 4 curved tines on each side and we put ten bales up at a pull... But unlike Brian, we had a hay hoist up in the mow and there was the 'guide/trip' rope and the start-stop-brake rope and one man could put up hay without somebody else around but two people worked better, one setting and tripping and pulling the carriage out while the other ran the start stop and assist in pulling the carriage out...  Sure was fun when you could slow that bale fork down just before it reached the setter's hands so he could grab it and swing it around to set on the front or the back set of bales (4 and 4 with 2 length-ways in the middle) then step the tines in on one side, step over and set the other side, step back and the start rope would be pulled and start lifting the bales... and if there are people stacking in the mow, they would holler "TRIP" and ten bales would land near they were stacking...
  When I first started helping with bales, we had 12 foot hay racks... which held exactly 20 bales to a layer and took only 2 settings to clear a layer...
 and then got 14 foot wagons and had a place to stand to finish the load and then place 4 up the front on each side...and threw an 'extra' rider on the fork, sometimes two... for 12 bales going up into the barn.
Then we got 16 foot racks and had 25 bales to a layer... first four layers were 100 bales and the next two layers were set half bale width in without the center bale down the middle and that was 34 or 36 depending on if you stacked them one-on-top of the other or did another 1/2 step and then the top tie of one across the middle.  Could figure those loads were 140 or so bales... If we knew we had enough wagons, then we stacked one layer less, or around 120 bale load.
  I did most of the stacking on the wagons back then, had 9 wagons that we could fill, and anything left after they were full, would be round baled up.
All the fancy layerings of hay would have slowed putting bales up in the barn having to reposition them for the bale fork... so that was the reason for a basic stacked load.  Biggest thing is to make good solid bales and stack the hardest sides of the bale to the outside which usually was the cut side and the knot end, but not always...
  Three wagons had the back standards and two had 30" sides and on the back and the rest had 2x4 edges and on the very back.
 Can't say we didn't lose any bales, but we never lost a bale on the road and we were up to 6 miles from home sometimes.   Can honestly say I hate them dang pocket-gophers and their mounds with a vengence.
 Later we got a throw baler and 3 throw racks and put in a hay conveyor. Don't like it that well, and some days I sure miss the old bale fork and nicely stacked wagons... bales were square and weren't twisted bent or crooked... or broken in the wagon.
 But now, most of the hay is baled up round and try to get some squares up for the calves and any cows that have to come into the barn... and to feed in the bunk during really bad weather.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2018 at 1:18am
I don't remember the dementions of our old hay wagons either, but dad always made them wider than anyone else, length was prolly about 18 ft or so, 4x6 stringers, 4x4 cross members and 1x12 floor boards with a 2x4 edge. we had steep hills and the 2x4 would usually keep the load on the wagon, not always tho. never had any with a back on them. would have been nice quite a few times. the dude that baled for us always made the bales heavy, so we would stack as high as we could throw them, sometimes we could get a higher load if someone was on the rack to stack. we didn't have far to take to the big stack at home. and he didn't work us to death when it was hot.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2018 at 8:52am
20x8 wagons
1 |==
2 ==|
3 |==
4 ==|
Cap |lll|
I put the 3 center bales on their edge and one on each side flat. I stagger the next rick opposite from the one in front. 25 to the Rick makes it easy to count. If going any distance I strap the front and rear across. Never had a problem and I don't let anyone walk or stand on the bales as we are loading. That will make a loose load in a hurry.if they can't put the cap on without standing on the next rick they get to load from the ground. By the way I got straw to bale in the next few days if anyone wants training , training cost will be low!!!
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2018 at 10:01am
Allisrutledge you should have had them time the GOTO at gray to coincide with your straw and you could have had "demonstrations" and probably charged for letting us pick up straw
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2018 at 11:38am
Hmm, next time, but let's not tell anyone.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2018 at 4:50pm
I tie the second stack in with the first. This way you also have steps to the higher bales. On the second tier you place a bale that is on both the first stack and over the bottom of the second stack. This way you never have a stack of bales that are not tied into the next stack. After you have five bales at the back you would need to start the bottom of the second stack before completing the second tier.
Clear as mud I suppose without a picture.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2018 at 8:52pm
There is a reason why hay wagons have a slanted back.  As you stack and keep pushing bales to the back each row partially overlaps the row behind it and adds to the stability.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2018 at 10:37pm
A local auctioneer puts one wagon on his trailer.  Then he pulls that wagon up on top of the other wagon.  Then he pulls the two stacked wagons on the trailer.  I don't think he would want to go any higher!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2018 at 10:47pm
Ted...the ones with the slanted backs are for loading the bales with a 8-pack loader on a tractor, when loaded the bales will all be flat and then over lap about a 1/2 bale backwards on each level. it's for load fast and "git"! usually not many bales on each load. not like hand loading. you'll see on the front of the loads how they are stair stepped as they go higher. plus it keeps them from rolling off the back
cabinhollow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2018 at 6:14am
I have been stacking hay by hand for almost 50 years and it has always been on a slanted back wagon. 2"-3" overlap per layer. Also, stack with the outsides straight ( gaps inside the stack) for the first 3 layers, then let the next layers start sloping in. Here you are going uphill or downhill or around the side of a hill. Sometimes all within 50'.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2018 at 6:57am
I took over Dads custom baling when I was 15 years old and at 80 I still don't use a back standard on my wagons.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2018 at 7:51am
Any back we had on a wagon, someone would always pull under a tree, simply gave up on them.  We use the same wagons for big rounds as we do for square, and the backs are almost in the way for rounds.  We "tie" a temporary 4x4 on the back and front when hauling rounds, acts like a chock so they don't roll off.  The steepest of hills, just don't take the wagon there, bring the hay to the wagon, or the bale didn't stay up there anyway!
PERSONALLY, a preference, all this talk of "tie in", is one approach.  My method, the stack can give A LOT without going off, and if you hit a chuck hole or something, one corner will give, and not fall off (within reason).  And in the event that you do lose a few bales, you only lose a few, and don't loosen the rest of the stack at the same time.  Any luck, I'll be square baling tonight and I'll post a pic.
Proud to be unique! LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2018 at 10:11am
Sorry about the poor pictures guys.  Like the hay hook in the view here, lol.  Was in motion and very bright out and I didn't see it.  So that's my daughter driving.  Deere 2555, NH 273 baler.  Too cold to bale at like 69F  Was 97 on Sunday, shoulda started then!!!
So this is what the overhang typically looks like, not 30% like I said, more like 15%, helps make a nice wide base, and the side boards dish it upwards ever so slightly.
The finished product.  This is the field where I learned that a rolling harrow, even with a  buster bar, does NOT fill in uneven areas from plowing and discing! LOL  So the back of field is rough to begin with, and then last years was so wet made ruts round baling.  So this load is only 5 high, and only 4 bales on the 4th tier.  With good heavy bales and a little smoother ride, I often put 5 on there, no problem.  And same goes for 6th tier, would be 3 up there, but this load is getting backed into a shed that 6 won't fit under, waiting for a customer, so no point in putting them up there just to take 'em off and haul them home.
Same load.  The brown short crappy looking ones on the lower left of the pic are the ones left in the baler from last year.  There are 109 bales on the wagon.
My daughter in front of the barn my Grandpa built.  Not sure how much longer the ol' barn will be with usCry  This is a nice 6 tier load, 115 on this one.
Typical photo of round baler inaction.  That's not a typo, space left out on purposeAngryAngryAngryFriggin' contraption anyhow!!!
Sorry, not the best of pics, but thanks for looking.
Edited by Tbone95 - 22 Jun 2018 at 10:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2018 at 2:31pm
Thanks for posting the pictures. Love that barn and I am always jealous of flat hay fields. Riding my hay wagon is like a rollercoaster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2018 at 9:32pm
TB,
Your windrows are about 1/3 size for me. ( have a inline baler )
And your wagon load is about 2/3 what I do on my hills.
I start on the steep parts for the first 1/2 of the load, then go to the not so steep parts to top off the load. 150+ bales per load
And I am getting ready to dump my wagons. Just about have two bales sweeps built.
When I get it all setup, I will move 40 bales to the barn at a time, from the seat of the tractor.
And the barn, if it was on my farm, my wife would be making me turning it into a house for her. On the plus side, she would let me park my B in the living room.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2018 at 10:55pm
I learned to stack from my Dad, not sure where he learned to stack. Apparently we like to utilize out hayrack space! We stack our hay against the back on 8x16 wagons. We have rolling hills but nothing extremely steep. And all fields are right down the lane from the farm.
1st level    ===
2nd level   l==l
3rd          ===
4th          l==l
5th          ===
6th           lllll
www.awtractor.com
A&W TRACTOR 920-598-1287
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 12:29am
We always stacked on the truck like bradly6874 said, but only 7 high, with the long bale in the middle on 7th tier..it's not that way this time...but ya get the idea
But this is the way I like to stack em
Edited by Michael V (NM) - 23 Jun 2018 at 9:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2018 at 7:01am
Originally posted by cabinhollow cabinhollow wrote:
TB,
Those windrows are very small, not "typical" of what I do.  Dad raked it......not sure why he didn't double them up.....maybe to be sure it dried.  Very dry this year too, so hay is short.Ouch
As I said earlier, I often put 120-125 on a load, and this one was only 109.  Nice place to stop right by the driveway!Wink  And besides, some of my ol' tires aren't worth the risk of big loads.  Doesn't save any time anyway.....especially when a tire blows going down the road and you get to change a tire and restack the load!  Haha.....Original question was, guy wanted to stack around 100 bales.
Edited by Tbone95 - 25 Jun 2018 at 7:03am
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2018 at 7:18am
We put 48 bales on a load
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2018 at 7:45am
Cheater!
Charlie
farminharmon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farminharmon Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2018 at 1:18pm
Tier 1:  =ll=
Tier 2:   lllll
Tier 3:  =l=
Tier 4:   llll
Tier 5:   lll
Tier 6:   =
Tier 7:    l
4 rows of these for 104 bales then very front row is 20 stacked as so.
llllll
lllll
llll
lll
l
Total wagon load of 125 bales.  Works perfect.
B110 CA D10II (2)D12III 5040 5050 6080 170
JD5205 Kubota M9000 Kubota M95S
