Harbor freight stud welder
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Harbor freight stud welder
    Posted: 26 Feb 2025 at 7:52am
Anybody tried one.
I’m in need but don’t know if I’d ever use it again???
Don’t like to buy Ont time use tools.
Any idea of quality?
I’ve read good and bad just wanting real world information.
Edited by Thad in AR. - 26 Feb 2025 at 8:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 8:07am
NOT the HF unit, but body guy's used one for 3+ decades.he uses 1000s of the studs  every year. Bought in NC..I call it the porcupine machine..another Canadian invention.
Really a simple device not much to go wrong. Bit of a 'learning curve' but it's the PROPER tool for doing quality tin work !
3 studs removed the dent in ,my #1, D1-14 gas tank 15 years ago.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 8:14am
I have to ask (I’ve been wondering about this) what safety precautions you took to use this on a gas tank? I can see this being used for this purpose.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 8:29am
if we ever had to weld on a tank at work, shop rule was empty, blown dry and then dry ice chunks to force fumes out and leave CO2. If you can’t do that, I’d drain, flush, and fill with water JMHO
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 9:28am
rinsed it several times with water, blew dry.
soldered several rider tanks  same way.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2025 at 2:10pm
gas tank welding - empty , rinse , run exhaust from car into tank until to hot to touch , let cool and weld or solder .
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2025 at 6:12pm
Got a 96yr old uncle that has been welding gas tanks like that with an ox/acetalyne torch for 70+ years.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2025 at 10:41am
I have welded on small gas tanks and never a problem. But one mistake is all you may get.
Forty years ago, I saw the after math of a mistake. In a tractor junkyard. A 55 gal barrel strapped to water wagon. The barrel was the bigger gas tank for a pump to spray water on construction sites. The consensus was the strap was being cut with a torch. This was a yard that had done very little scrapping, and I know the water wagon had been there years. And a part of town any gas would of been taken very soon. So it was empty, but the old time gas was different than todays. But those fumes went boom big time. The man doing the cutting never made another mistake.
I have wondered is using the exhaust from modern clean burning cars still a good way to remove the oxygen from the tank?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2025 at 4:34pm
what comes out of the exhaust pipe is CO  ... neither will burn.. The goal is to PUSH all the gas fumes out and leave a blanket of no oxygen... You can also use Nitrogen or CO2..
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2025 at 10:18pm
I kept the exhaust flowing as I brazed....still here. Not endorsing it.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2025 at 6:48am
I wouldn’t be buying this for gas tanks but to use on my truck project. Helps to think about future uses when buying a tool that won’t get used often.
