half gears in d 21
timmypuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timmypuller Quote  Post ReplyReply Direct Link To This Post Topic: half gears in d 21
    Posted: 01 Oct 2014 at 12:15pm
i need to replace the clutch in my d 21 and while i am at it i would like to put in some half gears. could i make the low range of the range tranmission the half gear. i would then have a 5 1/2,6 1/2, 7 1/2 and 8 1/2 in that range and 5,6,7 and 8th in high range? any info on who could do this and what cost would be?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2014 at 12:32pm
If you're serious about doing something in the trans, call Mark Gettinger. 765-977-9348
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2014 at 12:34pm
Engler, Humpco and Atlas tractor.
I'm close to Atlas, Carl is good, but is just plain over worked it seams.  I've always had great luck, but I know some people have had issues getting their parts in a reasonable time frame.
brads180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brads180 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2014 at 9:28pm
I used Mark for my D-21 did great job and was done in the time he said it would be done.
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2014 at 11:36am
I run Marks trans in my 8070, he can build you whatever you need.
Making a living farming with and working on Allis Equipment
