H4 won't move |
Page <12 |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42270 |
Posted: 20 Jun 2017 at 8:12pm |
On my HD4 I lost reverse - when taking the shuttle valve apart - one of the springs was broken - not allowing the proper movement of the internal valve to line up with the proper port - I matched up a spring in my junk spring collection - trimmed it to size with a grinder and had it back in service on the job in about 2 hours .
That small slide valve needs to be centered over right ports to apply hyd pressure to clutch pack . |
Randaleky
Joined: 17 Aug 2011 Location: belfry, ky. Points: 427 |
Posted: 20 Jun 2017 at 8:13pm |
Any springs broke in the valve ? there are plugs on the front of the shuttle valve that is operated by the lever, the plugs can be removed one at a time and insert a pressure gauge to see what is being transmitted from the pump at 1500 rpms.
Monte
Posted: 20 Jun 2017 at 11:04pm |
The springs looked fine.what pressure should I be looking for? I really think something, somewhere is stopped up. The shuttle shift valve is getting warm within 2minutes of running. First thing in the morning, I'm going to let it warm up and follow the hot lines until, hopefully I find a cool spot and that should be my blockage. I just hope it's somewhere outside of the transmission.hopefully it's a collapsed hose.
Coke-in-MN
Posted: 21 Jun 2017 at 8:30am |
there is a filter in that system - also I believe a suction screen - don't have the circuit picture and memory is a little foggy on full routing - believe the filter was to front of machine (steel lines)
Monte
Posted: 21 Jun 2017 at 8:36am |
Yes. I have a new on waiting on me at the parts store this morning. I cleaned the old one yesterday. I haven't checked the screen yet. This maybe the problem.Its located on the left side of the transmission under the machine...... I think. I'm not looking forward to checking it. I pressure washed the dozer and it's a muddy mess under there.lol
Monte
Posted: 21 Jun 2017 at 10:16am |
It was pretty dark in the shed it was parked in and I didn't notice it has a prolonged parked mark on the dipstick. I wonder if it's possible that it's low enough to show full on the cold mark when running because it isn't priming the converter..... I hope I worded this so everyone can understand what I'm thinking. I'm going to wait 6hours and check it and see if it is full.
Monte
Posted: 21 Jun 2017 at 10:17am |
It says 6hours min.
Monte
Posted: 21 Jun 2017 at 3:28pm |
It only shows to be a quart low.so, the pump is definitely putting it somewhere as soon as you crank it, because the fluid drops probably 3inches on the stick immediately. I'm back to a blockage.... . I hope....
Monte
Posted: 21 Jun 2017 at 3:32pm |
If the converter was bad, how could I tell?
pinball
Joined: 28 May 2014 Location: missouriu Points: 6458 |
Posted: 26 Jun 2017 at 1:48pm |
Did you ever find your problem
Monte
Posted: 26 Jun 2017 at 1:54pm |
No sir
Ferdinand
Joined: 31 Mar 2016 Location: North Carolina Points: 1951 |
Posted: 26 Jun 2017 at 10:24pm |
From that description, I'm thinking it works like an automatic transmission in a car. Are there places on the transmission to attach a pressure gauge? On a non-working automatic transmission, one of the diagnostic steps is to put a pressure gauge at specific test points. Typical automobile transmission that I work on has 4 test ports. |
Because narrow is the gate, and narrow is the way, which leads unto life, and few there be that find it.
Mathew 7:14 |
Page <12 |
