H3 track rollers
badtrack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote badtrack Quote  Post ReplyReply Direct Link To This Post Topic: H3 track rollers
    Posted: 13 Jun 2016 at 3:27pm
Hi back on the 1964 H3 carriage. Looks like I may be in need of up to 5 new bottom track rollers. The well worn ones are Berco 1388. Does anyone know where I may search for them or seals and bushings?
Josh H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 8:51pm
Might not be available but call berco. I think I've bought direct before
Post Options Post Options   Thanks (0) Thanks(0)   Quote badtrack Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 4:15pm
Thanks Josh. I think I may have found so used ones but expensive.
arichi55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arichi55 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 6:31am
Try industrial tractor supply
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 8:07am
If you have, or have access to the tools you can rebuild them. Strip them down, build up rollers by welding and turn back to specs. Time consuming but works. Make sure you have the necessary parts for reassembly before doing this much machining.
Post Options Post Options   Thanks (0) Thanks(0)   Quote badtrack Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 7:54pm
I found some Berco 2163 rollers. After installing the rear rollers on a worn undercarriage I found the sprocket digging into the roller! The center diameter of the 2163 is 3/4 inch larger than the old 1388 roller. Any idea of the easiest fix??
