H3 track rollers |
badtrack
Joined: 02 Oct 2015 Location: United States Points: 39 |
Topic: H3 track rollersPosted: 13 Jun 2016 at 3:27pm |
Hi back on the 1964 H3 carriage. Looks like I may be in need of up to 5 new bottom track rollers. The well worn ones are Berco 1388. Does anyone know where I may search for them or seals and bushings?
Josh H
Joined: 24 Feb 2015 Location: Carnesville, GA Points: 128 |
Posted: 14 Jun 2016 at 8:51pm |
Might not be available but call berco. I think I've bought direct before
badtrack
Posted: 15 Jun 2016 at 4:15pm |
Thanks Josh. I think I may have found so used ones but expensive.
arichi55
Joined: 14 Nov 2015 Location: lake George,NY Points: 5 |
Posted: 22 Jun 2016 at 6:31am |
Try industrial tractor supply
ac-mike
Posted: 23 Jun 2016 at 8:07am |
If you have, or have access to the tools you can rebuild them. Strip them down, build up rollers by welding and turn back to specs. Time consuming but works. Make sure you have the necessary parts for reassembly before doing this much machining.
badtrack
Posted: 29 Jun 2016 at 7:54pm |
I found some Berco 2163 rollers. After installing the rear rollers on a worn undercarriage I found the sprocket digging into the roller! The center diameter of the 2163 is 3/4 inch larger than the old 1388 roller. Any idea of the easiest fix??
