H3 pto
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Topic: H3 pto
    Posted: 28 Sep 2021 at 6:35pm
I have an H3 with a pto. Was told that in d15 with shuttle the pto is not the right speed. My h3 dozer has a shuttle, so does the pto run at the right speed (540)? Would like to run a pull type brush hog with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 7:01pm
Rev it up and put a tach on the pto shaft..Wink
Beam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beam Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 8:38pm
The manual states it will run at 540 at around 1650 rpm (I don’t have access to it now to get exact RPM) regardless of gear. I’m going to add the tach on mine in order to ensure mine runs at 540.
1962 H3, WD45, B210
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2021 at 3:58pm
I borrowed a H3 with a pto and I used a 6' bush hog type mower with it with no problems. I also had a H3 LB and with no pto. I installed a hydraulic motor on the bush hog and used the hydraulics for the backhoe to drive it and it worked well also.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2021 at 7:58pm
H-3 PTO has a gear box at the rear which corrects the PTO to standard 540 when equipped with the shuttle.  D-15, I-60/600/615 does not so has non standard PTO speeds
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 11:18am
This is what's on my HD 3 , let's say if a guy had a extra unit what would a good working PTO Unit be worth .
nonetheless ,still dead.
