H3 Bottom track rollers
bursco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bursco Quote  Post ReplyReply Direct Link To This Post Topic: H3 Bottom track rollers
    Posted: 05 Jul 2020 at 4:21pm
Hello all
first time on this site directed here by John from tractorparts
I recently acquired a couple of H3 dozers hoping to build one good one but I am having difficulty with bottom rollers, I am looking for some decent used,new or aftermarket bottom track rollers or maybe if someone knows of another roller assy that can be modified to work. I would very much appreciate any help in locating these
Thank You
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2020 at 4:25pm
I think those are gettin near the unobtanium point, now, but I'll give the post a bump.  Several here monitor these type posts....Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote bursco Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2020 at 4:29pm
thank you I appreciate that
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2020 at 4:34pm
May need to consider looking to other machines as to similar but not exact, redrill roller trucks and set new if at all possible. The old rollers if still relatively sound could be welded up and machined back true if just a hobby machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bursco Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2020 at 4:50pm
I was thinking of welding up a few of the better ac trucks but I also have some of the Berco's where the roller looks good but the internal parts are ate up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2020 at 6:09am
Bearings may be available aftermarket or if bushed could have a machine shop rebush and change out seal configuration to something that is available instead of the Allis Bellows seal assemblies.
This page was generated in 1.156 seconds.
