H3 160 cu in gas engine build |
Page <12 |
OldSchoolRecovery
Joined: 06 Nov 2015 Location: Eagle River, WI Points: 301 |
Posted: 25 May 2016 at 12:03am |
Thats why the sleeve/piston set is $700 more than the 138, 149 motor. Special, Old |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35692 |
Posted: 25 May 2016 at 12:16pm |
I would dress the threaded area up, smooth off the broken edges and check for cracking into the bolt boss but would not attempt to weld or fill that spot, if need be I would drill and add a KEENSERT to the bolting threads for strength.
OldSchoolRecovery
Posted: 26 May 2016 at 12:40am |
Crank came back bad. Cracked.
Rethinking project until fall, Old
Kevin in WA
Joined: 08 Feb 2010 Location: Lynden, WA Points: 615 |
Posted: 26 May 2016 at 9:57am |
Actually the 138 149 and 160 all have oring grooves in the block, but the 160 block has a larger counterbore, so they won't interchange, 160 also has larger wrist pins and are full floating.
125 engines have oring grooves on the sleeve. |
Page <12 |
