H3 160 cu in gas engine build |
Page 12> |
OldSchoolRecovery
Joined: 06 Nov 2015 Location: Eagle River, WI Points: 301 |
Topic: H3 160 cu in gas engine buildPosted: 19 Mar 2016 at 9:33pm |
All,
Starting a build thread for my H3 160 cu in gasser. I think there may be some differences from the tractor D15 II. Check it out. For staters, my engine had to pistons stuck, which can be found in an earlier thread, but this one is for the rebuild. Here is the block stripped and ready to be sent out to get cleaned and cracked checked.
OldSchoolRecovery
Posted: 19 Mar 2016 at 9:36pm |
Here are all the casting numbers and stampings on the block.
OldSchoolRecovery
Posted: 19 Mar 2016 at 9:37pm |
More
OldSchoolRecovery
Posted: 19 Mar 2016 at 9:38pm |
Another
OldSchoolRecovery
Posted: 19 Mar 2016 at 9:40pm |
Last
OldSchoolRecovery
Posted: 19 Mar 2016 at 9:41pm |
Appearently this motor has been rebuilt at least twice before. Not sure about the crank and another regrind....
OldSchoolRecovery
Posted: 19 Mar 2016 at 9:43pm |
Second grind
OldSchoolRecovery
Posted: 19 Mar 2016 at 9:44pm |
Crank casting number
OldSchoolRecovery
Posted: 19 Mar 2016 at 9:47pm |
Here is where I see a problem with my dozer. Looks like someone put a tractor cam in it as there is no lobe for the mechanical fuel pump. The previous owner blocked this off and used an electric pump. I dont want to use a electric pump. Where do I get a cam with the fuel pump lobe?
OldSchoolRecovery
Posted: 19 Mar 2016 at 9:48pm |
Exterior fuel pump boss and hole, and cam without corresponding lobe??
OldSchoolRecovery
Posted: 19 Mar 2016 at 9:51pm |
Oh, and a tool I made with my $500 auction lathe from last summer, for driving out the cam bearings...
Is the middle bearing supposed to be copper and the outer two babbit??
OldSchoolRecovery
Posted: 19 Mar 2016 at 9:53pm |
Anyway, any comments would be appreciated, especially pitfalls, etc...
What I do know is the 160 engine kits seem to be more costly. Who will have the most parts I need at a reasonable price. One stop shop, etc..?? The block goes in this week, will update when that comes back.. cb1
Edited by OldSchoolRecovery - 19 Mar 2016 at 9:56pm |
OldSchoolRecovery
Posted: 20 Mar 2016 at 11:42pm |
So far,
$350 for overhaul kit except Mark II, $1075 for Mark II, Holy crappers.... $700 for 11 cubic inches... cb1
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55292 |
Posted: 21 Mar 2016 at 5:08am |
Does the right cam come with the kit, fer that $700?
OldSchoolRecovery
Posted: 21 Mar 2016 at 12:22pm |
Nope
orangeman
Posted: 22 Mar 2016 at 4:15pm |
Old School: I don't have this on fact, but was told at one time Allis thus Agco did not release the 160 gas engine kit to aftermarket production. On the other hand 149 kits were released and therefore the lower cost in the aftermarket production. Why the difference...? Perhaps someone on the former Allis dealer side could explain this better than I. There is enough talent on this board and members that could probably machine the 160 liner without too much effort.
The 160 gas can be found in other industrial units and I suspect that if you need to have the fuel pump then a source might be someone parting a 160 gas industrial block. Have you checked with Tony's tractors - he did advertise at one time on this site. Since the 160 gas uses the TSX 815 updraft carburetor it would be reasonable to assume that gravity feeding the carb would work thus eliminating the absolute need for the fuel pump ~ unless you intend an application for the dozer where you will be on severe grades. More questions...let us know. Orangeman
OldSchoolRecovery
Posted: 22 Mar 2016 at 4:26pm |
Orangeman,
Thanks for the reply. At first, I too didnt understand why it would not have been gravity fed, and then thought, yes, dozer sometimes get themselves upended in ditched, etc and if you were there for a while, the carb could run dry. Here is a dumb question. Will the 149 kit work in my block?? or is the block bored bigger for bigger liners?? Quite a big hit in hp, so probably wont go that route. Probably just bite the bulllet and get the overhaul kit. Just found one for $1038, so thats $35 less than the last one I found. I am also going to check with the shop I am taking the block to. They are in farm country (Antigo, WI) and maybe they have different answers. Going to have them look at the crank and see what they say about 040 on the rods. If I had sleeves made, I would have to get pistons anyway as two got distroyed on the dissassembly. Thanks, cb1
Edited by OldSchoolRecovery - 22 Mar 2016 at 4:33pm |
OldSchoolRecovery
Posted: 22 Mar 2016 at 4:29pm |
Oh, and I forgot. I think the cam is a crawler only deal, unless someone knows what other model(s) cam with a manual fuel pump.
cb1
orangeman
Posted: 22 Mar 2016 at 4:46pm |
Old School: Some more to share - in discussion with the Factory personnel, was told that the 160 gas engines did find some Military application. As such, the military wanted to insure positive pressure to the carb. I have not been able to confirm the Military application of the engine, but did find it in stationary power units and used also for irrigation applications.
I have a unused 149 kit in the garage and could mic the dimensions if that would help. Would like other forum members comment on whether an 160 block can use the 149 liners and pistons - there is a substantial cost savings to be had between the 149 and 160 overhaul kits. Hopefully, others will come in here to chime in. Good Luck this will be a good post to follow...Orangeman
orangeman
Posted: 22 Mar 2016 at 4:50pm |
Old School: Check on the Forklift side of things - as some of the Allis Forklifts used a 160 gas engine. Not sure of the forklift models that carried the 160 gas or if they have the fuel pump. Seems like they would contained the fuel pump on the rough terrain fork lifts.
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6061 |
Posted: 22 Mar 2016 at 5:28pm |
There was a discussion about these engine kits last fall when agco listed the 226 gas engine kit as being on indefinant backorder. The short version of that discussion was that you want to order a power max kit for you motor. Power max makes the oem style power crater pistions. If you use a kit with a flat top pistion you will end up with a major loss of compression. I think indefinant backorder might have been the name of that thread in the farm equipment forum. The power max kits are not cheap but they do carry the correct pistons so you will get the 8.25 i think it is compression ratio. Nothing worse then putting all the work into a rebuild and having it come out with less power.
Dan73
Posted: 22 Mar 2016 at 5:33pm |
Oh you might try posting on the farm equipment forum asking if someone has the engine parts you are looking for. Someone posted recently that they wanted to know if they could swap a 149 into a tractor that had a 160 because the 160 had a cracked block maybe between the two motors you could build one good one.
OldSchoolRecovery
Posted: 22 Mar 2016 at 9:55pm |
http://www.allischalmers.com/forum/forum_posts.asp?TID=78886&title=160-vs-149-engine
So, different blocks 149 vs 160.. cb1
OldSchoolRecovery
Posted: 18 May 2016 at 10:37pm |
Block back from cleaners.
OldSchoolRecovery
Next picture
OldSchoolRecovery
Posted: 18 May 2016 at 10:38pm |
Last picture.
OldSchoolRecovery
Posted: 18 May 2016 at 10:40pm |
Here is a picture of damage from past owner using a bolt a little too long. Will need to fix this..
OldSchoolRecovery
For mounting the water pump..
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 19 May 2016 at 7:01am |
I have a few 160 bare blocks, some liners, cranks, rods, pistons. I have saved them from mostly farm tractor, and industrial I60-I600.
Edited by JoeO(CMO) - 25 May 2016 at 1:56am |
Brad in WA
Bronze Level Access
Joined: 29 Sep 2009 Location: Lynden,WA Points: 199 |
Posted: 24 May 2016 at 11:59pm |
149 has orings on the sleeves, 160 has them in the block, sleeves will not interchange.
Page 12> |
