Grease zerks |
cidrmakr ![]() Bronze Level ![]() ![]() Joined: 01 Mar 2012 Location: Washington Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Mar 2012 at 6:53pm |
I have an 1952 Allis CA. Seem to recall that there was a grease zerk for the throw out bearing. Can anyone confirm that there is or is not. And, how do you get to it.....
Thanks, John |
1953CA ![]() Orange Level ![]() ![]() Joined: 01 Jan 2011 Location: Burlington, WA Points: 505 |
Should be under the torque tube, where the clutch inspection hole is.
Andrew
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support" |
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
The zerk is for the yoke not the bearing its self. The zerk is on the under side thru the inspection slot just back of the throw out bearing. I have taken several apart the the zerk was gone.
I thought I had a picture but couldn't find it just now.
