Grain Cart Size For 7045 & 8030
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: Grain Cart Size For 7045 & 8030
    Posted: 13 Nov 2017 at 4:43pm
What would be the best size of grain carts for both of these tractors?
Thanks & God Bless
Dennis
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2017 at 4:56pm
No grain cart is too big for an Allis! Clap
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2017 at 5:02pm
Got a 500bu one on our 7045. Drawbar pushed in. 9 weights on the front. If we were to go any bigger, would probably have to do some kind of a drawbar support.
AllisandGleaner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2017 at 6:22pm
We use a 400bu on on out 75 hp Deutz it is 4 wd and has all the weights on the front of it. We haven't had to run the drawbar up or anything. As of now we have not had any problems out of it.
SCJR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SCJR Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2017 at 6:44pm
We used to have a Kinze 800 on a 7030(doubled the drawbar). Remember when grandpa took the drawbar to the ground when it was on his 220 with 850bu of milo on it.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2017 at 9:40pm
Had our 875 J&M on our 8030 last year it was fine. To play it safe I would be careful of hills.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2017 at 10:12pm
also depends on if the cart is just gonna be parked to act as a holding bin, or if you are gonna be in the field meeting the combine. not everyone pulls them thru the fields.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 7:21am
Power Shift trans would be a huge plus on any grain cart.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 7:49am
I would suuuuurrre love to find a 400 - 500 Bu grain cart that wouldn't require a second mortgage.....
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 8:19am
Power shift would be nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 8:46am
I'll take it!  How much?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 9:27am
Always curious on why the guys with big carts don't have a dolly wheel setup hooked to the cart hitch to take weight off the drawbar, like a tractor trailer pulling doubles hitch, guess itd be a pain in mud
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 9:58am
Because you need the weight on the rear wheels of the tractor to get enuff traction to pull it when loaded.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 10:22am
jeez knowing what our 800 does to our 8550 drawbar I cringe thinking about a cart on a 2wd.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 10:26am
And, you need to be able to back up easily when topping off trucks. A dolly just turned it in to a wagon lol!
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 11:48am
We run a John Deere ( I know not orange but in its defense it was made by United Farm tools lol) 1210a grain cart on our 7040. It has wooden sideboards on it so probably holds closer to 450 than 400 and it works fine. Though there are much better balanced and just overall better carts out there. We did put a set of gleaner combine tires and rims on it last year so that makes up for it being green.
ryan
John D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John D Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 12:19pm
There is a nice Brent 474 (I think) with scales and tarp near me (not mine) that is available - I can put you in touch with the owner.
1964 D17 series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 12:32pm
Me?  Boy.....that would be a long drive pulling a grain cart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 2:30pm
Tbone i bet my old cart is still sitting unused just outside of Traverse City.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 2:32pm
That I could handle!  Wink
Any way you can find out anything about it???
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 3:56pm
If you don’t hear from me remind me. I don’t think I have his number but could find it on a map easily
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 5:21pm
I don't think there's near enough engineering put into these grain cards. Did you ever stop and figure how much weight went into them? And then there's stopping, uneven ground, speed, tractor to weight ratio, there's no end to it. Seems to me a little less weight and a little more safety would be in order. But I understand trying to save or make a dollar because no one is going to do it for you.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 6:21pm
I pull an eztrail 510 and also have an old a&l 650t (tandem) and have had them on 7045 and 7060 without doing any modifying of anything and got along fine so far. We don't dump on the go but use them in fields or places we can't get the trucks easily. I go slow and we have flat land. You sure know either one is back there!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 6:44pm
Neighbor has a 500 bushel on his 140 HP green tractor, 2 wd and duals with fluid in the inners. I have had the combine drive out from under me going up some hills( cause of wheel slip) when there is over 300 bushel on it. I even had to back down one hill this fall because the sand knob was loose and damp from a recent rain.
 I chase the combine all day and have no other problems than the steeper hills and sandy ground. It works good for loading his 520  bushel gravity wagon, but ya about need a funnel to load the 300 bushel rusty wagon or the 300 bushel pup trailer on his pick up.
 AND you GOTTA have the auger empty to shut the PTO off or drive anywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 6:38am
If you don’t think a big cart is safe buy a smaller one or don’t fill it all the way. It’s like everything else a little common sense is in order. I highly doubt they need changing
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 7:33am
Got our 305 on the 800 bu grain cart. Only way to go.
Ya cain't fix stupid.
