Governor spring pellet
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Topic: Governor spring pellet
    Posted: 03 Jul 2020 at 8:02am
Ran across a RC tractor that was once used for pulling...why was the pellet taken out of the governor spring.....just a plain old spring...thanks in advance..Mark
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2020 at 3:46pm
RPM increase. You wouldn’t believe some of the things I seen done to those things. Wrapped that spring with string, wire ties, bailing wire. About anything to keep the spring from spreading. If you ever watch an AC at a antique pull and the driver never lets go of the throttle, probably has the governor spring tied up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2020 at 5:20pm
The early (1939) RC's had a different throttle/governor spring and arm as compared to the later models which had a spring/plunger arrangement. I had one of those old ones and the governor worked poorly. didn't take long to round up the parts to update it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2020 at 6:34pm
Thanks Dr. Allis...could not find the spring I had in my books...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2020 at 8:38pm
Change it over to like what a C or CA or D14 has. I left the arm that crosses over in front of the engine and welded to it to make it like a newer one. Changed the spring/plunger and arm that they attach to.
