Governor for Hand Crank B
holmesk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote holmesk Quote  Post ReplyReply Direct Link To This Post Topic: Governor for Hand Crank B
    Posted: 07 Sep 2010 at 9:16pm
Governor broke on my hand crank B.  Assume this is the case since engine took off at high RPMs and something broke out a quarter-sized chunk of metal from the governor housing.  I also assume I need to buy a replacement.  Is there a difference between the governor for a hand crank and the governor for an electric start?  Is there any chance a broken piece could have made its way down into the crankcase?  Wondering if there is a need to open the engine to be sure it's clear.
Thanks
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 10:36pm
I think there is a good chance that a stray piece could have dropped into the front timing cover area.  I have a  WC parts tractor that the governor broke and a piece dropped down and took a couple of teeth off of the crank gear and broke the camshaft gear. I think it would be a good idea to have a look!!
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 7:30am
Ah yes, the forum just had this discussion - Dick L gave a very good post-mortem on the situation.
NO.
YES. But that wouldn't be a problem - it'd just sit on the bottom of the oil pan, slowly becoming a fossil - oilpannicus junkosaur.
YES. Front timing cover anyways. If you cannot recover all those pieces - then having one bouncing around endlessly in the timing gear area IS a problem. Besides, aren't you getting tired of that front crank seal leaking?
It was very short-sighted on Allis Chalmers part to not design that governor to last 60 years - unconscionable...
Post Options Post Options   Thanks (0) Thanks(0)   Quote holmesk Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 9:34am
Great help guys...thanks!
