got tire chains...
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: got tire chains...
    Posted: 13 Feb 2011 at 6:39pm
Just got a set of tire chains...free. Now I just need to see if they are the right size, I just eyeballed... The set together probably weighs more than me. Should be entertaining for the dog LOL. I'll let ya all know how they fit.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 6:41pm
Now that sounds like my kind of deal. Congratulations.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 6:45pm
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 7:00pm
Free is my favorite price!  LOL!
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 7:06pm
I'm sure they are the right size if they were free. It's all I can do to lift one of my chains, but when you need em and they're on the tractor, the wrestling match is well worth it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 8:04pm
I'll give you $1.00 for em and pay for S/H.  That way you can make money.  LOL  Good deal !!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 9:15pm
I lay the chain down behind the tire face down then back the tractor on the chain, run a wire (no9 wire) through the rim and wheel center next to a spin lock (not near the valve stem) then just back up until you see the chain on the back side of tractor.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 9:22pm
Got one side on, about 2 cross bars too long so I cut them off and zip tied up the extra links. They are a bit narrow and hang over each side wall about an 1-2 inches so I used a ratchet strap on the outside and I'm going to put one on the inside as well. drove it to the road and back and it didn't start to walk off yet. Will be a trial and error as this is my first set on a big tractor.
German Shepherd dad
#WD234847
#WD88193
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 10:09pm
 Next year you can put them on  on a nice sunny fall day its alot more fun than in the cold and snow
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 10:19pm
Once I get new tires they may not fit. I can probably at least trade them for a set that does.
German Shepherd dad
#WD234847
#WD88193
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 6:48am
You should try putting chains on 4 - 20.8 x 38s some time.  Dad used to custom grind hay, and the 7060 was the loader tractor, and when the customer's lot was on a snow packed ice covered hillside, we had chains on all four rear tires.  Would take longer to chain up, and tear down, than it did to grind the hay.  It was even more fun when it started to thaw on those warm winter days, and that greese layer formed.  WOOHOO, that I don't miss!! :)
Still in use:
roughstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 4:49pm
I jack up the tire and roll mine on. It took about an hour to get one side to fit. They fit tight. The other side I wrestled with for about two hours before I went and bought a couple add a links. Glad you hear you got em on!
Brian
This page was generated in 0.227 seconds.
