Gleanor z
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Topic: Gleanor z
    Posted: 19 May 2013 at 8:19pm
I'm looking at a z engine and was wondering is there anything to look for
if farming was easy everybody would be doing it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2013 at 8:33pm
As in what???? The only difference is the compression ratio. Other than that it's exactly the same as any other Gleaner model E engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2013 at 8:36pm
Well I was wondering if there was any problems .is there any z engine better then others referring later vs earlier
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2013 at 8:53pm
Does the z have the highest compression ratio
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2013 at 7:32am
I am pretty sure it does, 8:1, I think, A little searching here will answer your question...
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
