Gleaner Z question
graveyard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner Z question
    Posted: 10 Mar 2014 at 11:01am
I have a gleaner z 226 in my d 17. Has anyone ever ran the mechanical fuel pump on this motor in pulling?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 12:19pm
There's no need to do that. Some Antique Clubs wouldn't allow it. Suit yourself.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 4:57pm
Gravity flow is plenty, the pump is just more parasitic drag... and one more part to fail....
pohlman249 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pohlman249 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2014 at 8:52pm
Just get rid of the sediment bowl and run street elbows in1/4 pipe to a shut off then a filter and drilled out 1/8" pipe into the carb and open up the needle and seat if you already haven't and that should be more then enough file flow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2014 at 7:49pm
I actually have done that. Have no gas problem just seeking information!! thanks guys
This page was generated in 0.101 seconds.
