Gleaner N5 hydraulic oils
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner N5 hydraulic oils
    Posted: 09 Nov 2022 at 12:34am
Want to change hydraulic system from transmission fluid to hydraulic oil. Just empty the tank and replace with hydraulic oil? Or is there bleeding/ flush necessary? Thanks. Dale
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2022 at 8:47pm
If no hydraulic components have failed, I would clean tank and screen, and refill with good oil. If there has been a failure, flush every hose, clean tank, clean oil cooler, drain hydro, and any thing that you can get to. You cannot clean enough.                 MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2022 at 12:31am
Thanks Mack....No failures...I wanted to make the change and had the filter out and cleaned the tank...Dale
