Print Page | Close Window
Gleaner N5 hydraulic oils
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=191706
Printed Date: 26 Sep 2025 at 9:34pm
Topic: Gleaner N5 hydraulic oils
Posted By: orangereborn
Subject: Gleaner N5 hydraulic oils
Date Posted: 09 Nov 2022 at 12:34am
Want to change hydraulic system from transmission fluid to hydraulic oil. Just empty the tank and replace with hydraulic oil? Or is there bleeding/ flush necessary? Thanks. Dale
Posted By: MACK
Date Posted: 09 Nov 2022 at 8:47pm
If no hydraulic components have failed, I would clean tank and screen, and refill with good oil. If there has been a failure, flush every hose, clean tank, clean oil cooler, drain hydro, and any thing that you can get to. You cannot clean enough.                 MACK
Date Posted: 10 Nov 2022 at 12:31am
Thanks Mack....No failures...I wanted to make the change and had the filter out and cleaned the tank...Dale
