Gleaner N part |
orangereborn
Topic: Gleaner N partPosted: 13 Nov 2025 at 2:09pm |
looking for used auger hub (tube end with rollers) for N5 (all L's, M2, all N's?) part 71333439..Thanks....Dale 7157812055
Posted: 13 Nov 2025 at 2:28pm |
I would prefer to call it the unloader tube "swivel". You can go as new as an R-42/52 up to about 1993 ?? If you'd find a combine that had been in an engine fire.
orangereborn
Posted: Yesterday at 12:34am |
I was told that fitment may follow into the R series. I am aware of where there is an R5 and was going to check it out.. Some opinions are it was a little more than a simple swap? Thanks for the confirmation. Dale
Daehler
Joined: 23 Nov 2010 Location: Lexington MO Points: 1166 |
Posted: 16 hours 21 minutes ago at 8:03am |
R5 wont fit a N. Completely heavier swivel on it plus eliminated the chain. They should of just implemented it on all machines when it was introduced.
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
Posted: 11 hours 2 minutes ago at 1:22pm |
Small frame R-40/42 or R-50/52 prior to 1993 same as an N-series.
orangereborn
Posted: 8 hours 50 minutes ago at 3:34pm |
OK...Don't go look at the R5...I have a lead on one from an R52 that is included in the serial # sequence. Anyone remember the size of the bearings? about 128/130 needed? Anyone used the plastic aftermarket ring? Thanks for jumping in and helping out...
Dale
Posted: 8 hours 31 minutes ago at 3:53pm |
I don't think the plastic after-market design will run as many years as the ball bearing design, but I don't know that for sure. Are you wanting to replace all the ball bearings just because ?? If you do, there should be a space of about 1 full ball when done. Do not fill the track clear full. 1/2" diameter balls I think. If I was going to go to that extreme, I'd rotate the inner ring 180 degrees to get at least half of the ball track moved around. This will require cutting off one of the studs and welding on a new stud to get it to fit back onto the tank outlet.
