Gleaner M2 valve coil and slip ring part numbers
WD45 Aaron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner M2 valve coil and slip ring part numbers
    Posted: 28 Aug 2023 at 6:10am
Anyone have a part number for the hydraulic valve solenoid coils on an M2?
Also, I'd like to know the specs for these coils (watts or amps). I need to replace part of the harness and I want to make sure that I size the wire correctly. I'm thinking #12, but I'm not 100% certain.
Lastly, there's a slip ring on the clutches on each side of the machine. I need those part numbers too. Probably the same one. I think the only difference is that one gets a grease fitting and the other doesn't.
Thanks in advance,
Aaron
Edited by WD45 Aaron - 28 Aug 2023 at 6:30am
Machinery rescue for all things rusty or broken. Current residents include 3-1/2 WD45s, Oliver Row 77 gas, 88 diesel, Farmall super C, parts C, two Cat D2's, Clark C500-80 forklift, and a sick Kubota.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 3:02pm
I've made some progress. The part number for the coil appears to be 71188504. What I call a slip ring they call a brush holder, part number 71314325.
Now to find good used parts.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 3:49pm
Oakley Combines
Oxford NC
919 693 4367
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 4:21pm
AGCO has them new but the price
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Aaron Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 4:09am
8070nc,
Thanks for the info. I will give them a call. I have a call in to my local Worthington's. Haven't heard back yet.
Alvin,
 You're not kidding. What confuses me a bit is AGCO's online parts lookup calls it a 6 volt coil. I haven't studied the wiring diagram a lot yet. This would imply that there's a voltage regulator somewhere knocking the power down to 6 volts. That seems strange. Why would they do that? It would draw twice the current.
