Gleaner K, Pics and more Questions |
Page <12345 6> |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8469 |
Posted: 17 Aug 2016 at 9:48pm |
That's what I would've thought.
CrestonM
Posted: 17 Aug 2016 at 9:49pm |
Wow! It's on my bucket list to visit all the "Crestons" I can find.
TREVMAN
Joined: 04 Jan 2010 Location: Regina,Sask,Can Points: 1635 |
Posted: 17 Aug 2016 at 10:37pm |
I tried to pull one of my E's backwards, one wheel spinned the other direction. I too thought its just a gear jammer, put it in neutral. Didn't work. Pulled on grass about 50 feet and it was o.k. then hit gravel...bang...twisted the axle. Welded it in place, if I had to do it again I would have fabbed up a coupler like on the newer combines. I'd trailer it, Trev.
CrestonM
Posted: 17 Aug 2016 at 11:00pm |
Well that's no good!! So in other words, the only proper way to move it is by driving it. It wasn't designed to be towed.
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 17 Aug 2016 at 11:06pm |
find a dude that has a trailer made to haul them big self propelled sprayers, or those swathers, those pull behind a pickup good.
shameless (ne)
Posted: 18 Aug 2016 at 7:41am |
just to burst yer bubble a little....an N6 combine with 27 ft header and a header trailer just sold in OK.....for $2200. you could have paid for that combine with the first custom job prolly! whew!
CrestonM
Posted: 18 Aug 2016 at 7:44am |
Was there anything wrong with it?
shameless (ne)
Posted: 18 Aug 2016 at 7:56am |
nope
CrestonM
Posted: 18 Aug 2016 at 8:09am |
Well that makes me about sick....
Like the $250 7040.... Where did it sell at?
Edited by CrestonM - 18 Aug 2016 at 8:10am |
CrestonM
Posted: 18 Aug 2016 at 6:46pm |
Well I drove the combine today. I drove it around, but there are 3 problems.
1. Header will not raise/lower. 2. Variable speed does not work. (still drives good in all gears, but can't vary speed within the gears) 3. Separator will not engage. Is that some kind of a clutch? It seems like it's stuck. It just lugs the engine down and nothing moves. Pics to come!! Also...S/N is 3511, making it a first year 1969!
Edited by CrestonM - 18 Aug 2016 at 6:52pm |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3660 |
Posted: 18 Aug 2016 at 8:10pm |
It sounds like the hydraulic valves that operate the header & variable speed may have frozen up from sitting idle too long. This is a common issue. When the machine is operated, the hydraulic system builds up heat. When the machine is shut down, it cools down. In colder late season harvests, a more rapid cool down allows for larger condensation to accumulate inside hydraulics(valves, reservoir, pump, etc). This condensation moisture can freeze up & crack valves, ruin seals, plus simply corrode components. Try unhooking the hydraulic valve's control rods at valve plunger, then using some spray lubricant, a hammer, & a channel lock, tap& pry valve plunger in & out, until it moves freely. Re-install each control rod & try it. On a 1969 model K, these hydraulic valve bodies may be positioned back under engine radiator by hydraulic pump assy or they may be up under operators console right below levers? The separator clutch issue is also a common thing from sitting idle too long. Sometimes the rattle chain will be rusted in position? There is a rattle chain clean out access panel up under cylinder throat that should be opened & cleaned of grain, chaff, dirt, etc at the end of each season. This area also allows access to the rattle chain's idler pulleys. Lift header to aid removal of this access panel. Also check that all rotating items(augers, elevators, walkers, fans, etc move freely. If separator clutch is held by any frozen up items & engines pulls down long enough it may smoke the clutch linings and/or burn up the main drive belt. |
CrestonM
Posted: 18 Aug 2016 at 8:37pm |
The valve plungers DO move freely as of right now, but nothing happens. They are located where you said, back by the hydraulic pump. |
AC7060IL
Posted: 18 Aug 2016 at 9:04pm |
Ok. Hydraulic valves need to move a full range in each direction. Also, engine needs to be running at high idle. Hydraulics will not work or be sluggish at medium rpms.
If those all check out, then start looking for some hydraulic flow issue ( reservoir low on hydraulic ATF, hydraulic filter clogged, hydraulic siphon hose flacked off inside & clogged, hydraulic pump belt not tight, crankshaft belts that drive pto shaft may be slipping, hydraulic flow control valve blockage or bad, hydraulic pump may be bad)??? Good luck. Depending on your findings, the $1000 sell price may be lowering... |
CrestonM
Posted: 18 Aug 2016 at 9:08pm |
I'll check those things probably next week. Next Thursday is as soon as I could go back, as my college classes are my first priority (I only have one class on Thursday, though, so that's kinda my "free day"
Also, how should I free up the separator clutch? Edited by CrestonM - 18 Aug 2016 at 9:09pm |
CrestonM
Posted: 18 Aug 2016 at 9:45pm |
Here is 1 pic so far. More are on the way, as well as a video.
TREVMAN
Posted: 18 Aug 2016 at 9:48pm |
Didn't dude say "field ready"? All those things can be dealt with, but I'd take $500 cash and not pay much more. Neat little combine but just like my 2 E's, there is very little demand/interest in a machine that size. Trev.
CrestonM
Posted: 18 Aug 2016 at 9:49pm |
TREVMAN
Posted: 18 Aug 2016 at 9:53pm |
Looked at your post again...If you don't have header movement or variable speed, I wonder if you have any hydro power at all...Maybe just low on oil, Trev.
CrestonM
Posted: 18 Aug 2016 at 9:54pm |
I'm hoping that's all it is. What is type A transmission oil? ATF?
Edited by CrestonM - 18 Aug 2016 at 9:55pm |
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 18 Aug 2016 at 9:55pm |
I agree - I wouldn't give over $500 either. I only paid $600 for my EIII (one year older than that K) and it was in better shape, has a cab and 10' rigid head. Been using it for 8 years now. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
CrestonM
Posted: 18 Aug 2016 at 9:57pm |
Yeah, I'm thinking that too.
TREVMAN
Posted: 18 Aug 2016 at 10:12pm |
I'm gonna say that I think your separator wont engage because from the pics it looks like your chains are rusted in place...wow are they ever crispy. You are probably going to have to take those off, soak them in diesel or just replace them. I pulled an E out of a pond 6 years ago had been there since 1988, when I tried to engage the separator the engine stalled out. I soaked all the chains with diesel once a day for a weak, then poured atf on them. The engine then pulled the separator, but it was a grunt for a while. I took all the chains off, labelled them and let them soak in diesel over winter in the shop. Put them back on, slathered them in grease and they all still work. I do not have a shed so I slather the chains in grease after I am done fooling around with it in fall. Hope this helps, Trev.
CrestonM
Posted: 18 Aug 2016 at 10:25pm |
Surprisingly the chains have some wiggle to them. I'm going to spray them and then brush thick oil on them and see what happens.
CrestonM
Posted: 18 Aug 2016 at 10:42pm |
http://https://www.youtube.com/watch??v=G9pwynv_1Fc
[TUBE]?v=G9pwynv_1Fc[/TUBE] A little drive around video.
Edited by CrestonM - 18 Aug 2016 at 10:43pm |
shameless (ne)
Posted: 19 Aug 2016 at 2:06am |
looks to me like you were driving around looking for a place to get stuck? and that thing is NOT field ready, looking at the pics, it has sat along time, prolly both inside and outside. when I bought my "K" 15 years ago, it was on a dealers lot on consignment, paid $1500. it with all new tires, bearings, belts, chains, a 13 ft floating cutter bar with hume reel, and a 238 orange corn head. delivered! it is still not a bad looking combine, and with some TLC can be re-born again! I would not pay $1000. for this machine. $500 at the very most.
CrestonM
Posted: 19 Aug 2016 at 6:55am |
No, it's not field ready. The owner knows nothing about it or farming, so go figure. I might offer him $500, and if he says "Ok", then great. If he doesn't, I'll just move on. Simple as that! Besides, Mom and Dad don't like it anyway. Seems whenever I find a non-running Super 100, they don't like it because it "needs tires and doesn't even run". But this one does!......??? This was kinda funny....Mom also tells me I need to stop buying other stuff and save my money for a Gleaner (This is a Gleaner, right?) Well when I showed her the photos she said that wasn't what she meant. Apparently she meant a shiny big new one! Lol
Edited by CrestonM - 19 Aug 2016 at 6:58am |
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 19 Aug 2016 at 7:06am |
My uncle has a cherry low houred late model K for sale. $2,000 would take it. Otherwise it will be at the Hamilton Auction in Dexter MN the 27th of August. I would have snapped it up myself but don't have the shed room. It's really too nice not to have under cover.
On edit I think the sale is actually Labor Day Edited by Lonn - 19 Aug 2016 at 10:06am |
Wink I am a Russian Bot |
jorstad brothers
Posted: 19 Aug 2016 at 7:10am |
save your 500 for a better one. there are a lot of gleaners out there in buildings. waiting for some love.
remember plunder than burn
CrestonM
Posted: 19 Aug 2016 at 7:24am |
I don't mind working on it to get it running. What would you guys say it's worth? I'm getting the feeling $500 is too much, based on what several people have said.
Edited by CrestonM - 19 Aug 2016 at 7:25am |
Lonn
Posted: 19 Aug 2016 at 7:37am |
I am told scrap is $100 a ton at local yard right now. And I wouldn't give that but if you are looking for a project then it's better than buying a rusted tractor that been sitting outside for 40 years and restoring that. And plenty of people do exactly that. It's in the eye of the beholder. It you really want it, what's $500 bucks and some belts and chains. Some people drink that up in the local bar in a couple months. I've never seen a cabless K BTW.
Page <12345 6> |
