Gleaner F2 Straw Chopper Pulley removal?
jason82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jason82 Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner F2 Straw Chopper Pulley removal?
    Posted: 29 Sep 2016 at 7:10pm
Having some issues getting the drive pulley off the straw chopper, so that I can replace the bearing and bearing housing behind it, I sprayed it, torch it, and used a air hammer, still can't get it to move. would anyone have any suggestions on how to get it off, I see there is three hole that got thru the pulley face, didn't know if there was a specific puller that would do the trick. any suggestions would help.
Edited by jason82 - 29 Sep 2016 at 7:26pm
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 9:20pm
The pulley isn't keyed to the shaft so you may be able to use a couple of large pipe wrenches to break it loose from the shaft. I wouldn't use those three small holes to try and pull from, probably just ruin the pulley by doing so.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 10:34pm
we weld a large grade 8  nut on the pulley centered over the hole with a bolt ground to a taper like a puller - weld 360 - this will heat the pulley - then screw the bolt in - instant puller!  leave the nut on - no need to remove - just paint...  this works on bin unloader as well..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 10:34am
Fine threads being the best choice, for more power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jason82 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 6:19pm
Welded a 1 inch grade 8 nut to the end of the pulley and used a air wrench, came right off. should of posted this sooner would of saved us hours of headaches, thanks guys for the info, gratefully appreciate the help.
