Gleaner E engine
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner E engine
    Posted: 17 Dec 2016 at 8:41am
How important is it to have the Gleaner E engine for pulling? Can you build a regular old 226 to the same specs? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2016 at 9:16am
The Gleaner model "E" or "E-3" is a G-226 engine, already configured at 63 or 67 flywheel HP. You can spend the money on a lower HP W-226 and get the same results, but the G-226 has larger main bearings and a somewhat stronger block to begin with. How much HP do you think you need??
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2016 at 9:56am
Thanks, Dr. Allis. I wasn't aware of the larger mains and stronger block. I'm not sure what I am going to need, but I will be competing in 3500 and 4500lb open classes at local fairs. Will likely need more cubes.
This page was generated in 0.199 seconds.
