Gleaner E engine..what needs changed?
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner E engine..what needs changed?
    Posted: 09 Apr 2015 at 12:07pm
Picking up a good running Z code next weekend...what all needs changes to put it in my WC? I know it's been covered but the search function works terribly on my phone. Thanks!
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
rowcropmafia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2015 at 2:02pm
It's been a while since i have done it but if i remember right you need to turn out the center of your wc front pully to fit on the gleaner engine. You might need a small notch in your frame on the right side were the front cover of the engine is. You need to change governors if you want your governor to work correctly although i never did do that to mine   (makes loading and unloading on the trailer more entertaining if you don't especially with hand brakes and no 3rd ramp). I might have missed some things as it's probably been about 10 years and i have only done it once
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2015 at 2:04pm
You might have to swap water pumps also. I cant seem to remember why you needed the front pully from the wc. Im sure if i was looking at the tractor it would come back to me
Jesse48ia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jesse48ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2015 at 5:11pm
you can machine the bore of the wc pulley all the way through to get it to line up. The gleaner e has a longer crank snout. Then when you line up the belt you can drill a new set hole for the bolt You have to use the wc wd wd45 water pump enlarge the holes in the pump to accept the larger studs on the e engine. If your e engine has the fuel pump take it off and make a blockoff plate. You will have to re-bend the bottom oil line to clear the steering. Change the governor out it isnt that hard to do hope this helps a little
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2015 at 8:18pm
Thanks guys. Any idea what it would dyno at?
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
40wc47puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 40wc47puller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2015 at 1:59am
Water pump ..enlarge holes ..crank pulley from wc enlarge holew oil line needs bent gov from wc with e gleaner spring....hang on
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2015 at 7:42am
Either change front cover or put the tractor linkage in the gov. housing.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2015 at 7:43am
Might Dyno 50 to 60... Most combine engines were worn out due to dusty conditions, and they ran wide open all the time.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2015 at 7:23pm
I have several complete front covers if you would need one and decide to go that way.
This page was generated in 0.293 seconds.
