Gleaner A2 finally running |
Sandknob
Joined: 12 Sep 2009 Location: Oblong, IL Points: 2456 |
Topic: Gleaner A2 finally runningPosted: 12 Mar 2010 at 2:32pm |
I have finally got my 64' A2 Gleaner running. I bought a 262 engine out of an early F from my parents neighbor. It ran good, just needed to be mounted to the A2 engine cradle. Once I got it mounted to the cradle (which I painted while it was off) I was able to use a forklift and mount it to the combine. I did have to adapt the fuel line as the two carbs were slightly different. I also used the rotary screen (in front of the radiator) off of the F as I believe it will work better in corn. Finally got it all wired up, fuel lines mounted, filled coolant, and fixed batter cables I got it to run. Two nights ago I was able to drive it under its own power (probably the first time in 10 years it had moved under its own power). I just got one hydraulic line repaired (from pump to header) so hopefully I can get the 240 corn head off and switch it to the 330 head. I also plan to pull the cover off of the threshing cylinder and have a look see at the cylinder bars. I may end up turning them around if they are wore too bad. I am planning on giving it a workout this fall on two patches (one 4.5 acres, one 5.5 acres).
Adam
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 12 Mar 2010 at 6:17pm |
Adam, Good to here the A2 is up and going.
I had to put wheel weights on my A to keep the steer axle on the ground with a 330 head on her.
I used WD front wheel weights on mine.
Don
Oldoug
Posted: 13 Mar 2010 at 8:59am |
I like seeing the old Gleaners still going too. Great job on saving this one!!!
