Gleaner 320 Flex Head
badjeep View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote badjeep Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner 320 Flex Head
    Posted: 18 Sep 2019 at 4:19pm
Picked this 320 up a couple weeks ago, does anybody have any quick tips or tricks I need to know before bean harvest here in about 3 weeks? We got some good rains this year so I will be dealing nice tall beans. Thanks for any quick advice.
In the shed- 7020,7060, L2 X (2), CII, WD X (2), 200, 210, 611H, 440, Fiat Allis 345B
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 9:19am
Make sure the bar flexes real nice. When I first got my 315 for the L2 it was real stiff so I had to take all the pivoting parts apart and clean them up and oil real good and I think I used a lot of never seize. Then later years I added 12" wide flaps evenly staggered across the reel that extended about 3" past the teeth, I moved the auger up to about 3/4" off the floor and forward as far as possible. I got all these tips from this website and the combine forum. I believe some have made it so the auger can go further forward that what the adjustments normally allows and then you'd have to add addition chain length. I also cut at an angle and catch the tipped over beans on the return pass.
Oh and do a super job of cleaning out under the cut bar after use and spray lots of oil up there to prevent it from stiffening up again. My 315 spends all it's time inside but I still do that as a preventative measure,
Edited by Lonn - 19 Sep 2019 at 9:35am
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 9:37am
And make sure the reel isn't so low that the teeth can get caught in the cut bar when it's at it's most extreme flex. I replaced all my teeth with plastic just in case but made sure I never cut any off because they ain't cheap either.
Edited by Lonn - 19 Sep 2019 at 9:38am
Wink
I am a Russian Bot
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 9:37am
Ditto on what Lonn said. We have a 318 and a 320 for the L3's. The 320 has shorter feather sheets and sickle is 4" closer to the auger. It does well in shorter beans when cut at an angle. The 318 has been a good unit also. In shorter beans, we try to run the floating sickle as low as possible so the beans don't have a hill to climb to get to the auger. We don't use the header control at all but most of our ground is level. Make sure you grease wobble box and sickle head daily. We have poly skids and that helps also. Good luck
Leon B Mo
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 10:34am
Yes I have poly skids too and I put a 3" flexible drain tile just behind the cut bar using conduit clamps and the guard bolts to hold the clamps.
Here is a short video of mine.... I had more to say in the bvideo but I think my Ipod ran out of storage space right at that moment. It worked soooo much better after these few mods.
[TUBE]Nkt_q_5LjTc[/TUBE]
another one before I finished putting all the flaps on 3" past the teeth.
[TUBE]HaGT7NpM56Q[/TUBE]
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote badjeep Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 3:23pm
Thanks for the info guys, another thing, I noticed you didnt have the outer row guides or whatever they are called on your header in your videos, is there a certain time a guy should or shouldnt use them? i would rather just take them off, Thanks
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 3:52pm
The outer gathering dividers were there and they are the long dividers like yours, not the short. I should have done better with taking the video. I thought maybe the shorter dividers might do better but never had any to try out. I do have pics somewhere of the flexible drain tile mounted behind the cut bar that I could post. It's just that 3" pipe like they use when they tile out a field, very flexible and the outside diameter is actually about 3.5".
Edited by Lonn - 19 Sep 2019 at 3:55pm
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote badjeep Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 4:46pm
These dividers have a bunch of adjustment, it looks like I could shorten them up about a foot before they got in the way of the reel. Maybe I will go that way. Is there a need for them to be so far out in front of the reel that I am not seeing? If you find the pics of the drain tile mounted I would like to see it if you get a chance. Thanks for everything.
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 5:58pm
We used 2" suction hose w/2" conduit clamps held on by the guard bolts.  I bought a flexhead from an early rotary and swapped the reel for one with plastic fingers and got rid of the wood bats/steel tines.  Our head has Crary guards which break if a steel tine gets caught in them.  IMPORTANT: if your combine has the variable speed header drive, slow it down to its slowest speed and then disconnect the hose, otherwise you can overspeed the sickle and cause serious problems with the wobble drive.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 7:03pm
If I remember correctly, there are three bolts you put in the sheve to lock it at proper speed. You can then leave hose connected. Check owner manual for proper directions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 7:16pm
That hose is plugged into reel speed on head after slowing header drive down.....
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 7:28pm
Looks like I deleted those pics from my phone sorry
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 7:31pm
on my L2 I just disconnected that hose and the reel speed ran off the hydraulic system on the head itself using the combine electrics.
Edited by Lonn - 19 Sep 2019 at 7:32pm
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 7:45pm
Try this link and scroll down to flex head mods. There's a pic and description there.
gleanerhypermods.com/Headers.html
Wink
I am a Russian Bot
This page was generated in 0.143 seconds.
