gleaner 226 motor/combine parts |
Randy(Mo)
Joined: 13 Sep 2009 Location: Jefferson City Points: 523 |
Topic: gleaner 226 motor/combine partsPosted: 25 Jan 2021 at 9:21pm |
Parting out E gleaner, motor, header and any other parts you need, combine will be going to scrap, except motor, if nobody needs parts. this motor will also work in a d17 or wd tractor. text is best or call 573-690-3033. message will also work. can deliver smalls to Boonville swap meet on March 5 or 6
Mo Allis Club member
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 26 Jan 2021 at 8:14am |
Have often wondered this: Will a WD or WD-45 'W Series' motor bolt up in place of a D-14, D-15, D-17 'G' Series Motor ? G |
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4582 |
Posted: 26 Jan 2021 at 10:05am |
Will fit WC-WD-WD-45-D17. Will not fit a D14/15.
I've parted three Gleaner E's and all engines went into tractors Will have to or should use a tractor governor
Edited by Calvin Schmidt - 26 Jan 2021 at 10:06am |
Gary
Posted: 26 Jan 2021 at 4:22pm |
So that means a D-17 is a 'W' engine ? |
Randy(Mo)
Posted: 26 Jan 2021 at 8:30pm |
Motor is sold
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8965 |
Posted: 29 Jan 2021 at 11:32pm |
No it's not a W engine. It is the same on the rear so it will bolt into WC/WD/WD45 chassis but the problem comes at the front end as D17 used longer pulley. There are "work arounds" but not just "bolt her in". I believe they are "G" engines.
Posted: 30 Jan 2021 at 6:41am |
W-201 and W-226 are from WC-WF-WD-WD45. The G-226 was from D-17's-170-175.
Gary
Posted: 30 Jan 2021 at 8:03am |
Thanks Dr. So a D-17 G 226 will bolt up to a WD Torque Tube, but some mods are required at the front in order to install in a WD Eg crank pulley. G |
