Will this loader fit a allis chalmers D15 series 2
toddkatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toddkatz Quote  Post ReplyReply Direct Link To This Post Topic: Will this loader fit a allis chalmers D15 series 2
    Posted: 18 Jul 2017 at 8:16pm
Does this loader have the oil resevoir in frame?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 8:30pm
I do not see any reservoir and front pump.  Will it fit on a D15?  Couldn't tell you, but anything can be made to fit with enough welding/butchering.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 8:44pm
the RH upright is also a oil tank you can see the pipe plug under the control valve and the bottom part of frame is also part of it, as can be seen with the large hose from the valve goes down to the tank/frame
Edited by JoeO(CMO) - 18 Jul 2017 at 8:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 9:52pm
all loaders have to be modified with dif brackets to fit any tractor!
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 10:03pm
 That 1/2" coupling with a plug in it that faces to the rear of the vertical reservoir is the oil level overflow.  You give a Farmer a nig welder, a cuttin torch and a 4 1/2" angle grinder,,,and  a couple three days and he'd have that thing mounted and workin,,,,no problem,,,,,ClapClap
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 2:14am
Looks a little heavy...
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 4:04am
I have a loader on an I600 I'll sell should go easily on the D15
