Onan Generator CCK Vs Tractor CCK
Heliarc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Topic: Onan Generator CCK Vs Tractor CCK
    Posted: 07 May 2025 at 1:01pm
I'm working on an Allis Chalmers 720. Has an Onan CCK engine. CCK is the prefix of the model# on it anyhow and I think that's how you refer to them. I'm hearing Onan parts are really hard to come by anymore. I have a chance for an Onan generator engine for $50.
There's a 4B in front of the CCK but would there be enough interchangeable parts to make it worth while? Cylinder heads, pistons, con rods etc? I can't read much else on the data tag.
The engine on my tractor is CCK MS-2733J
Edited by Heliarc - 07 May 2025 at 1:05pm
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2025 at 11:03am
Most of those genreator engines don't have oil filters.
The CCKB-MS are rated at 20 hp @ 3600 rpm that genset engine is governed at 1800 rpm you would have to adjust the governer to get your needed HP. That generator may only be rated at 16 hp.
Not sure with is wrong with yours, but there are overhaul kits still available.
I am currently rebuilding one of mine.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
June View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote June Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2025 at 11:17am
I have a 916H Garden Tractor and tiller for sale. I need to know where I can advertise this tractor. I can't seem to post after I registered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2025 at 12:51pm
Gotcha. Mine runs fine but the charging system is only putting out only 5.5VDC so I wondered if the stator and regulator on something like this would interchange. Also sometimes my starter motor doesn't want to engage the flywheel properly. I got the tractor after it sat for over a decade so I figure I can clean the starter up and have it work properly. Mainly just looking for any cheap spare parts I can get hold of.
