Wd45 hydraulics
alc609 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alc609 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 hydraulics
    Posted: 01 Oct 2011 at 9:02pm
Is it possible to put a remote for a dual action cylinder on a wd45? If so how? Or where could I find a pic or drawing of the setup?
Post Options Post Options   Thanks (0) Thanks(0)   Quote alc609 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 2:59am
Surely somebody knows
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 10:41am
I'm sure someone has more information but I would say any pressure  1 in control 2 out to the cylinder, flow is a one thing with the WD's there system is for pressure and low volume.  Flow back into the cap for the checking or filling.  Or maybe there is a way to drill out the cover behind under the starter for a return, maybe there a place already for return.
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alc609 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 2:50pm
I done a search and sent a guy a message for some pics that done it somewhat that way on a 17
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 4:11pm
Buy a valve like used on a log splitter, connect to your present remote line and run a return line to a tee in place of the drain plug. Bottom of the tee would get the plug, side would get return line. You can also add a filter housing and filter on the return line.To make it work, you have to have the original hydra lever in the up position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alc609 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 6:10pm
I don't think it has a remote at all, just the lines going to lift cylinders. Can I still make it work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 8:06pm
If there is no line there, follow the lift arm lines back to the AC valve and pull a plug out of the original valve. Hook your pressure in side of the new valve to one of those plugged holes. You lift arms will go up first and once they are up the 2 way addition will work.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 2:37pm
Alc 609 sent you a PM.
