D 15 engine removal |
Page <12 |
Dave(inMA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
And those pictures will help get #1 back together properly!!
WC, CA, D14, WD45
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 2979 |
Thanks Jay and Dave . I'm trying to take a couple pics of everything . Cell phone is a pretty good helper .
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24689 |
pix are great just be SURE to copy/backup to a PC or flashdrive. Wife's iphone recently had swimming leasons in the white, round swimmin hole...PU !
That ain't good Jay .
Have my engine upside down on the engine stand . Sure makes it easy to pull the oil pan . Rear main seal is very hard . Probably why it was leaking at high rpm . Anyone know where I can get a speedi sleeve for the crankshaft ? Thanks
WeisAC2 ![]() Bronze Level ![]() Joined: 02 Feb 2017 Location: Aiken SC Points: 112 |
wow that's a pretty oil pan. When you find the sleeve, you can 'practise' on 'Troy' here...lol. I just add oil 'as required'...too many minor leaks for me to worry about,specially since there's a LOT less seat time now.
Thanks Jay but I dunno . I'm hoping this will be my last "big" tractor job. Oil pan was off when I got this tractor so I hit it with a little primer before putting it back on . Crankshaft looks ok to me but if I can get a speedi sleeve I'd sure use it . Thanks for looking
Edited by ACinSC - 31 Jul 2020 at 8:11am |
My book says to apply a little lubriplate to the new rear main seal . Should I get some or will wheel bearing grease do ? Thanks
Rusty Allis ![]() Bronze Level Access ![]() Joined: 16 Jul 2020 Location: Rhode Island Points: 163 |
I have always been a fan of lubricating seals with whatever fluid they run in. whenever a mfgr suggests something else I have to think it's due to assembly time and they don't want a dry start. whatever you use, make sure it will melt fast once the oil hits it. I would be inclined to use assembly lube mixed with oil
Makes sense , Thanks Rusty Allis .
Now that I have things kinda cleaned up I see the trans engine clutch shaft seals are leaking . Anyone changed them lately ? Looks like you remove these 4 bolts and pull cover to get to them ? Thanks !!
Edited by ACinSC - 01 Aug 2020 at 3:01pm |
i 'think' there's a felt seal behind though be sure to drain tranny first.....
Yeah Jay according to the agco site there's 2 seals back there . Guess I'll find out . Thanks
Have it apart and the seals out . Two seals 211111 C/R . Gotta add 2 seals and a gasket to my evergrowing list . Thanks
Does the oil pump intake screen have steel wool looking stuff inside it like the oil bath air filter ? Sure hope that's what it is . Thanks !
Another question . Anyone familiar with the tube that runs from the base of the oil filter to the oil pump cover on the back of the engine ? Mine's leaking . Has what's left of rubber packing grommets in the connection . Guy at NAPA had never seen one . Hoping Sandy Lake has some . Thanks !! Now that I've cleaned them some I see Imperial Flex on the cap .
Edited by ACinSC - 11 Aug 2020 at 10:58am |
My fav son has posted a pic .
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8628 |
Those grommets come in various sizes. My 8070 has them on various lines. Should be available from AGCO.
Thanks Steve . Sandy lake has them .
Wonder what happened to the other pics on this post ? Thanks !!
GSTROM99 ![]() Silver Level ![]() ![]() Joined: 12 Dec 2020 Location: Greene, IA Points: 246 |
Yeah, I was reading thru this now and some pics are gone. Maybe they were "linked" and now the link is dead...
Dunno why Gary but they've been gone . Sorry
Page <12 |
