ACC 60 DS lift cylinder rebuild info needed
Message Reverse Sort Order
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: ACC 60 DS lift cylinder rebuild info needed
    Posted: 09 Nov 2024 at 12:11pm
JoeTX - After I finishing fall chores on the land - will take a look at my service section on the F-series Forklifts and see what that says.  We may need to go through email ` welcome to send me a private message on here ~ Orangeman
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2024 at 12:32pm
To remove that cylinder is definitely labor intensive. You really should be two persons and some form of a lift to do this repair job. if you haven't previously worked with resealing cylinders your best choice is to find a trustworthy and reasonable mechanic or hydraulic shop to refurbish the cylinder with new seals. The seals will be common types and sizes so they don't have to be Allis-Chalmers parts.
I'm including a link for a A-C forklift manual for sale, although with the right kind of help you may not need it for this repair job you're doing.
joetx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joetx Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2024 at 11:24am
I have an ACC 60 DS. My mast cylinders seals are leaking.   Can someone give some help in repairing these seals. Or is there a manual somewhere? Don't know how to approach this as I don't know know how to remove the cylinders to repair them. Thanks, Joe.
This page was generated in 0.041 seconds.
