1940 wc noise
Jeffy0023 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeffy0023 Quote  Post ReplyReply Direct Link To This Post Topic: 1940 wc noise
    Posted: 13 Sep 2010 at 9:40am
Hello, I have a 40 wc styled. I get a  kind of grinding noise. it is in the drive train. It hard to explain. Does not matter what gear or speed, if driving it only grinds when the govener applies power? It sounds like a bad bearing but something like that would consistantly make noise this has no pattern. The clutch does not slip. example driving the tractor up a grade the noise would almost chug along with the tractor as it applies and backs off power to maintain speed. Jeff
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 11:25am
Jeff, wheel clamps will make that kind of noise if they had been rusted shut for many years and all of a sudden broke loose for one reason or another.  Low oil in the final drives could also do that.  You are probably right about the bearing, I am just trying to be optimistic.
JohnDNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnDNY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 4:47pm
If it only does it when its moving check the wheel nuts first. As my papa always said, don't overthink the problem. HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeffy0023 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 5:29pm
I know the govener increases engine speed to maintain, But this thing sounds like the clutch is engaging then disengaging with the governer each time. like it only makes the noise when there is torque pressent, actually putting power to the wheels, if it rolls say down a hill in gear with clutch out it doesnt make any noise but as soon as you start up a hill it makes the grinding noise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 6:56pm
Mine does something like that. When you push the clutch in it is quiet but when you let it off you get a light noise.
I think it's part of a WC
This page was generated in 0.035 seconds.
